Author Topic: Ebay scam?  (Read 7528 times)
Re: Ebay scam?
« Reply #15 on: August 07, 2023, 02:52:14 PM »
That's an F1 but with a tank and side panels painted in the F2 blue.
Odd he has the tyre pressure warning label off a 400 four on the chainguard.
Looks to have been stood for some time.
Offline DomP
Re: Ebay scam?
« Reply #16 on: August 07, 2023, 02:55:20 PM »
It was ridden in 2017 then stored in his garage so will need some gentle persuasion I'd imagine.  Full going over and soak the piston rings in a little oil first before easing it over by hand?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline Matt_Harrington
Re: Ebay scam?
« Reply #17 on: August 07, 2023, 04:37:21 PM »
Well done and hope it turns out OK.
Re: Ebay scam?
« Reply #18 on: August 07, 2023, 04:47:45 PM »
My 400 had stood for 10-12 years PO had periodically cranked it over via kick start  - I managed to get it going after I had stripped the carbs as they were all stuck solid on the sliders.
Compression was not great - ended up needing a re-bore.
I guess it depends on how far damp air has entered the cylinders via any open valves - you might be lucky.
Offline DomP
Re: Ebay scam?
« Reply #19 on: August 07, 2023, 05:31:24 PM »
I'm prepared for some work to get it going but it's a good base for a winter project I think.
1975 XS650B
Re: Ebay scam?
« Reply #20 on: August 07, 2023, 05:58:44 PM »
When my 250 Super Dream had stood for 18 months back in the 1960s with a spark plug removed stored in a garden shed  I revived it using Redex down the bores. Took several days of squirting in the oil and pushing the kick start by hand but it did eventually turn over. I also had to remove the clutch as the plates had stuck.
Ran superbly once the smoke had cleared from the Redex soaking.
Offline DomP
Re: Ebay scam?
« Reply #21 on: August 07, 2023, 08:37:47 PM »
I'd imagine, or hope, the chain guard is off a cb400 because its been  removed and replaced at a later date with one off a 400?!
I'm sure I'll be asking on here for advice when I get it home.
1975 XS650B
Re: Ebay scam?
« Reply #22 on: August 07, 2023, 11:00:24 PM »
The 400 four chain guard isn't the same as the 550F one, which is why I thought it was odd. TBH it looks the right shape.
