Author Topic: Bearing Manufacturer choice  (Read 3923 times)
Offline Matt_Harrington
« on: August 06, 2023, 05:56:14 PM »
Is there much to choose between SKF, NTN etc when selecting new bearings for the primary shaft on a 400/4. I'm not trying to get the cheapest just decent bearings. I notice that some NTN bearings are made in Taiwan rather than Japan - this maybe irrelevant......
« Last Edit: August 06, 2023, 06:04:02 PM by Matt_Harrington »
Re: Bearing Manufacturer choice
« Reply #1 on: August 06, 2023, 06:32:16 PM »
NTN, SKF and KOYO all OEM standard bearings, they are all excellent. Some bearing you can only get from Honda but the 400/4 primary is available in the correct type from any of the above mentioned, if I remember correctly 🤔🤔🤔
Online Athame57
« Reply #2 on: August 06, 2023, 07:33:08 PM »
Back in the 1980s if I needed a wheel bearing etc I would take what I had to show at the counter of a bearing manufactor in Lewisham and they would provide an identical one that was British made and much cheaper!
1978 CB400F2 named Elen.
« Reply #3 on: August 06, 2023, 07:45:27 PM »
A lot of Japanese manufactures have moved to Taiwan since the 90's, including Riken, NTN and many more  ;)
« Reply #4 on: August 06, 2023, 09:20:24 PM »
Back in the 70's it was cheaper to get a Honda part with 20%discount than a british with 65%discount for wheel bearings
Offline Moorey
« Reply #6 on: August 06, 2023, 11:12:20 PM »
    The bearing grade makes a fair difference to the price of a bearing.  eg SKF 6205 c3 is £3 and a SKF 6205 C5 is £12. Anyone know what grades
    Honda use in the engines.
    Snap ring ones are getting a little costly now.
     https://www.ebay.co.uk/itm/143632266103?hash=item2171267377:g:jycAAOSwA7de1PkW&amdata=enc%3AAQAIAAAA4A3VM1rQb6B%2FpmZZd28jgy46pfHHPlAVbMfUKld1Fp7Gq81asoHuLo%2FWE3BEBPAQ5MP2Z%2FjI%2FCLbchskWQa0Zbe3AQQdC9gkXFqIkQ97whF6CvVWuCGSubRsc%2FCieEAjQHpjce9nCTLlqjCHKj%2BEYCfW1RZZf2nfyxfsGc6lQEEw9CJs8WIWvTWh3vLce1pLMiOhI4F2byoaWmHqg2Y4G7xebvFhyHq%2FMugq8Z7heQRbInZie%2BCDjjJy8%2Ftfaeq7%2Fo2wwqIV6C6WIXzvLna9JNsINV2tmf2ThGwT3MLhwUbZ%7Ctkp%3ABk9SR_qwj865Yg
C3 Chris. I can't remember ordering anything other than C3 for any of the engines.
Offline Moorey
« Reply #7 on: August 06, 2023, 11:23:32 PM »
 I just wondered if they were using owt different C3 is pretty much what you would call a standard bearing.
« Reply #8 on: August 06, 2023, 11:41:18 PM »
More modern bike with higher revving engines have more clearance. I have a bearing data book somewhere for motorcycles up to the year 2005 but, have not looked at it in years as they keep changing with higher revving engines on the gear box. All SOHC engines are happy with C3 Chris ;)
Offline Moorey
« Reply #9 on: August 06, 2023, 11:58:20 PM »
   Cheers.
« Reply #10 on: August 07, 2023, 08:39:45 AM »
Thanks guys, questions answered.
