Author Topic: Doms CB550F1 project  (Read 428556 times)
Offline DomP
Re: Doms CB550F1 project
« Reply #105 on: August 27, 2023, 07:55:32 PM »
Are you turning the air / fuel mix screw the right way?. Out for more air = leaner, in for more fuel = richer.
My bad! Yeah I turned it in rather than out by mistake
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #106 on: August 27, 2023, 08:06:35 PM »
Yea, that's what I guessed 😊😊😊
Offline DomP
« Reply #107 on: August 27, 2023, 09:11:50 PM »
Short of biting the bullet and stripping it down are there any tests I can do to detect what sort of wear I might have?  I think I know the answer to this one!  One thought I have had, could it be a weak or intermittent spark causing the roughness and therefore the smoking/smelling rich? The HT leads are pretty rigid and the coils a bit knackered looking.
« Last Edit: August 27, 2023, 09:19:54 PM by DomP »
1975 XS650B
« Reply #108 on: August 27, 2023, 09:31:49 PM »
My brief experience with coils is to look at where the HT leads just exit the coil if the outer insulation is cracked then they are probably part of the problem.
Offline DomP
« Reply #109 on: August 28, 2023, 09:00:19 AM »
I'm going to order some new ht lead and caps (plugs are new non resistor type) and do the 'Ash fix' on the coils to rule that out as a possible cause.  Could the carb sync being out be enough to cause it to sound so bad?  Going to get a load of airline to perform a carb sync as well and see where that leaves me, if all this doesn't solve it it is at least nothing lost and I can move on to looking at a rebuild.
1975 XS650B
« Reply #110 on: August 28, 2023, 09:03:04 AM »
If the carbs are not all balanced correctly, the engine will sound ruff  ;)
Offline DomP
« Reply #111 on: August 28, 2023, 09:05:43 AM »
In my haste I've only become synced,
1975 XS650B
« Reply #112 on: August 28, 2023, 09:19:47 AM »
If the clunking is that bad, you will find that the primary chain and rubbers are well past its best  ;)
Offline DomP
« Reply #113 on: August 28, 2023, 09:27:35 AM »
To be honest I'm a bit excited by the idea of splitting it, I've got room on the kitchen table now the carbs are back together too 🤣
1975 XS650B
« Reply #114 on: August 28, 2023, 11:28:14 AM »
If you are going to split i suggest getting as many parts as possible first.
Gasket set
Oil seal set
Primary chain (kawasaki)
Cam chain, see oddjob
Primary damper rubbers x 8 Honda and not cheap
Possibly cam chain tension blade
Probably cam chain cushion
Maybe pistons/rebore
Bank loan
« Reply #115 on: August 28, 2023, 07:24:11 PM »
If you split the casing you're looking at a potential budget of £1k plus a tad more if you need some gearbox bearings as well. These old bikes are like black holes with costs.
« Reply #116 on: August 28, 2023, 07:40:57 PM »
Check for bent valves and cracked valve guides  ;) And they are not cheap if you can get them .
Offline DomP
« Reply #117 on: August 28, 2023, 10:53:39 PM »
I'm prepared for it to be expensive, that's not really an issue as I'm in no rush and will be doing the work myself as far as I can.  Having turned the air mixture screw out to factory setting again I began syncing the carbs with some cheap ebay vac gauges and got it running a whole lot better and quieter.  Family life then intervened so I still need to finish tweaking but I think I'm getting somewhere.  Bit of a weep coming from the head gasket though!
1975 XS650B
Offline DomP
« Reply #118 on: August 31, 2023, 09:41:16 AM »
I've bitten the bullet and bought a Morgan Carbtune so I'll get the carbs balanced on the weekend.  Is there a recommended setting for the throttle stops?
1975 XS650B
« Reply #119 on: August 31, 2023, 01:20:56 PM »
Depends what you mean by throttle stops
