Author Topic: Doms CB550F1 project  (Read 428675 times)
Re: Doms CB550F1 project
« Reply #150 on: September 02, 2023, 11:24:36 PM »
I quite like the idea of a bit of cam reprofiling, if I find everything else to be in good order I may go down that route.  In terms of top end gasket and o-ring kits, where is best to get them?
Vesrah are a top kit and you will need more than a top end set  ;)
Offline DomP
« Reply #151 on: September 03, 2023, 11:30:38 AM »
I've got it stripped down and barrels off, I think at this point pictures will speak a thousand words, some good, some not so.  Here goes, I've not got a valve spring compressor so that bit will have to wait.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
« Reply #152 on: September 03, 2023, 11:32:24 AM »
There's more
« Last Edit: September 03, 2023, 01:28:56 PM by DomP »
1975 XS650B
Offline DomP
« Reply #153 on: September 03, 2023, 11:35:32 AM »
Apologies for the picture heavy content!
Cylinder 4, the small end bearing has some wiggle but the rest all seem fine from my very basic checks, all piston rings were free but the barrels don't look great do they?
« Last Edit: September 03, 2023, 01:29:33 PM by DomP »
1975 XS650B
Offline DomP
« Reply #154 on: September 03, 2023, 01:44:25 PM »
Things I've noticed are the pitting on 3x tappet adjuster screws, some rough and raised edges on two of the puck recesses, pitting to the valve side of the head, the bores are a little scored and one has an inclusion or something.
1975 XS650B
« Reply #155 on: September 03, 2023, 01:57:56 PM »
Looks like your in for a long winter getting that back to top condition. Tappets are cheap but, I can see where they have chipped away at the top of the valves.
Cam lobes don't look good and it will need a rebore with oversize piston kit at 0.50 or more  ;)
Cam chain guides look like any old guides and you always replace them.
Offline DomP
« Reply #156 on: September 03, 2023, 02:22:51 PM »
It's just the one lobe not that that makes things better, it's all doable I presume though and there's really no rush on my part.  Would I be best asking one of you to do any machining I need doing or look for somewhere near me and I'll need to as you all for advice on what a rebore entails such as new pistons etc.   Don't get me wrong when I say this but I'm looking to make it reliable and doing what's necessary but not spending where I don't need to.
1975 XS650B
« Reply #157 on: September 03, 2023, 02:32:20 PM »
Bryan J is close to you and he has a boring bar, knows the spec and knows were he can get a piston kit from  ;)
« Reply #158 on: September 03, 2023, 02:53:23 PM »
What's the barrel itself like Dom, any chipped fins etc. I'm thinking maybe replace the liners and rebore those so you can say just do an 0.25 overbore and save the rest for later, if ever.
Oversize pistons available at Cruzinimage pretty cheap and they seem ok from reports. Maybe check to see what the barrels clear up at before ordering. Either with new liners or with the old ones.
I may have some tappet adjusters. The valves with the damage may be able to be dressed up.
Got to say some of the rings look stuck in the grooves in a couple of the pics. Clearly 3 and 4 were not running well.
Head looks ok, camshaft journals not too bad. Rocker box is 550.
One thing I did notice, there appear to be springs fitted against the rocker arms, the 400 got similar but not the 550 to the best of my knowledge.
The camchain tensioner doesn't look bad, maybe check it's moves freely and replace the slipper if it does. The metal part should look straight from top to bottom, most seem to have a bend in them from bad fitting when amatuers take them apart. Check it's straight.
The camchain guide looks normal TBH, I've never replaced one of those unless it was damaged, usually bent.
With the state of the engine, clearly due to badly contaminated oil, I'm sort of dreading what the cranks shells are going to look like. Let's hope I'm wrong and they are fine.
Offline DomP
« Reply #159 on: September 03, 2023, 03:09:49 PM »
Thanks Trigger, I'll send Bryan a pm.
Ken, the barrels have a couple of bits of fin damage but pretty inconspicuous and ill be painting it if all goes to plan.  Your correct there are springs on the rockers, should they not be there?  Very small marks to two valves but I've also noticed a chip on the cm chain adjuster retaining bolt hole.
No stuck ppiston rings Ken, they are all free but thats immaterial i guess what with the bore wear, tensioner looks OK for straightness too. You're all suggesting I split the cases then, I'm dreading that bit, I can't get the kickstart off the splines for a start😫
1975 XS650B
« Reply #160 on: September 03, 2023, 03:11:03 PM »
Recently i have had a lot of my old barrels not clean at 0.25 as the liners have been egg shaped, so worth checking bore before ordering pistons.
You can call me on 07795162623 Monday to Thursday inclusive after 8pm when i am at work driving
« Reply #161 on: September 03, 2023, 03:22:50 PM »
Remove the pinch bolt on the kickstarter and force a screwdriver or a chisel into the slot, that should expand the slot and allow the arm to come off.
Offline DomP
« Reply #162 on: September 03, 2023, 03:42:04 PM »
I tried that Ken, I'll be a bit more gung-ho!
1975 XS650B
« Reply #163 on: September 03, 2023, 06:04:37 PM »
It is one of the mistakes that a lot of owners buy pistons at .25 and only 10% ever do clean up mate.
« Reply #164 on: September 03, 2023, 07:29:44 PM »
Yup, im finding them barrell shaped, fine at top and bottom but dont touch in middle, never found a step at the top yet though
