Author Topic: Doms CB550F1 project  (Read 423412 times)
Re: Doms CB550F1 project
« Reply #465 on: February 03, 2024, 12:53:29 PM »
Yours for postage only if you can use it. I will pop a photo up when I'm back home.
Offline DomP
« Reply #466 on: February 03, 2024, 01:22:36 PM »
Thanks Ted!  I've tried searching the correct spacer sizes for a 550f1 but can't find much so I'm relying on what is fitted being correct, currently it is 38mm long x 34mm tapering up to 38mm x 20mm bore on the sprocket side, 50mm x 35mm x 20mm bore on the brake plate side.
If anyone with an f1 can confirm these I'd be grateful.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #467 on: February 03, 2024, 02:00:46 PM »
The other measurements look the same as those you have posted for the hole size & thickness, bore 20 & 34-38 o/d diameter for the seal etc.
This spacer pushed my wheel off centre towards the right side so Max supplied me the correct one for my 500 that is about 3 mm shorter.
rear spacer by Macabe Thiele, on Flickr
Offline DomP
« Reply #468 on: February 03, 2024, 02:31:58 PM »
Can I just check but it looks perfect Ted.
1975 XS650B
Offline DomP
« Reply #469 on: February 03, 2024, 02:36:12 PM »
Actually Ted I'll take it if I may, I'll message you.
1975 XS650B
« Reply #470 on: February 03, 2024, 03:32:18 PM »
Item spoke for - going to Dom then!
Offline DomP
« Reply #471 on: February 06, 2024, 06:52:51 PM »
I want to replace my rear axle nut with a stainless one, does anyone know where I can get an m18 x 1.5 stainless castle nut?  Middleton only go up to m16 and ebay items all seem to be 1.75mm thread pitch
1975 XS650B
« Reply #472 on: February 06, 2024, 08:03:03 PM »
I suspect you need the right high tensile grade of SS.
Offline DomP
« Reply #473 on: February 06, 2024, 10:32:16 PM »
Yes I'd not considered that Ted, I kind of assumed they'd be suitable
1975 XS650B
Offline DomP
« Reply #474 on: February 11, 2024, 08:16:50 PM »
I picked up my rebored barrels from Bryan on Friday and dropped them off for a skim at a small engineering place in Hereford on my way home, with any luck I'll have the enginecall back together in a few weeks.  In the meantime I need to rebuild the front wheel once the rim has been powder coated, I'm thinking of economising with DS spokes rather than stainless, how resilient to rusting are they?
1975 XS650B
« Reply #475 on: February 11, 2024, 11:36:12 PM »
About the same as original
Offline DomP
« Reply #476 on: February 12, 2024, 08:15:03 AM »
My back wheel spokes were near to immaculate but may have been replaced at some point where as fronts are pretty corroded.  Cws are good and I've used them in the past but they're now £130 an end posted
1975 XS650B
« Reply #477 on: February 12, 2024, 11:26:56 AM »
Not that long ago I was groaning at them being £75! 😡
Offline DomP
« Reply #478 on: February 12, 2024, 12:16:07 PM »
It's hard to justify £130 to the 'bank manager'
1975 XS650B
« Reply #479 on: February 12, 2024, 12:28:27 PM »
An alternative would be plated ones on the front to match the rear? Would they be good enough to replate?
