Author Topic: Doms CB550F1 project  (Read 429192 times)
Re: Doms CB550F1 project
« Reply #495 on: March 02, 2024, 08:00:06 PM »
Not sure if abrasive dirt in the oil might explain the marking - if it's just surface marks might be fixable with slightly heavier fork oil - what do the insides of the fork legs look like - are they similar?
Someone like Bryan or Ken might know the reason for such wear.
Offline DomP
« Reply #496 on: March 02, 2024, 08:20:55 PM »
I think the legs are pretty good, I'll check again in the morning
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
« Reply #497 on: March 03, 2024, 09:45:22 AM »
Very little marking inside the lower legs, I struggle to understand how without bushes on the stanchion they don't contact the insides of the legs.  The damping rod has a bush I know but there must be significant flex in the rod
1975 XS650B
« Reply #498 on: March 03, 2024, 11:42:32 AM »
Might be worth a PM to Ken or Bryan - pretty sure they will know the cause & fix.
Online Bryanj
« Reply #499 on: March 03, 2024, 02:20:25 PM »
Some wear is frequent, those look fine to use to me
Offline DomP
« Reply #500 on: March 03, 2024, 04:48:24 PM »
That's a relief Bryan, I've reassembled them😀
1975 XS650B
Offline DomP
« Reply #501 on: March 05, 2024, 08:12:13 PM »
I began assembling the top end tonight, I've staggered the piston ring gaps if this really makes any difference as I've read they are known to naturally rotate in use, laid the gasket on with its orings and oil jets (got them upside down to begin with) then lowered the barrels over and fed #2 and #3 then #1 and #4 piston into their bores.  Leaving the 20mm gap I then inserted the cam chain guide and slackened off the tensioner and fitted it making sure it as in the pocket in the crankcase.
Having had the barrels skimmed I'm hoping the orings in the top of the oil jets will be sufficiently fat enough to prevent leaks.  I've fitted the head gasket and dropped the head on, at this point I'm going to ask if I'm missing anything?  I've got new pucks from Julie to fit s well.
« Last Edit: March 05, 2024, 08:14:13 PM by DomP »
1975 XS650B
Offline davidcumbria
« Reply #502 on: March 06, 2024, 07:52:04 AM »
With a vesrah gasket I did upsize the o rings so looked a bit tighter than yours, allowing for the squish. Pretty sure I used 2.75 thickness in viton but can’t be sure. I know I didn’t use the vesrah ones. Head was not skimmed. No leaks so far. I thought it’s  It s worth trying a few sizes to see how they look because they  are so inexpensive and having to remove head again is a big expensive job.
 The po had fitted the oil jets upside down on my bike, not realised and actually damaged the seat in the barrels - amazed it wasn’t leaking.
« Last Edit: March 06, 2024, 08:01:05 AM by davidcumbria »
Offline DomP
« Reply #503 on: March 06, 2024, 08:02:01 AM »
Yes I agree David, I might order some today, can you recall the internal diameter of them?  I'm at work so can't measure
1975 XS650B
Online Bryanj
« Reply #504 on: March 06, 2024, 08:07:36 AM »
As you have skimmed the block you dont need oversize O rings as the pockets are shallower so the ones you have will squish more.
Too much might close the hole a bit.
Rest of it looking good mate
Offline DomP
« Reply #505 on: March 06, 2024, 08:18:17 AM »
Thanks Bryan, the o rings are pretty much level with the gasket, will it crush that much?
I'll put a picture up with a steel rule so I can demonstrate how shallow the Vesrah o rings are
« Last Edit: March 06, 2024, 04:40:13 PM by DomP »
1975 XS650B
Offline DomP
« Reply #506 on: March 06, 2024, 09:20:48 PM »
I got home from work a bit early today, nothing to do with having a half built engine honest!  Bryan was correct, the new oil jet o rings were plenty proud of the gasket prior to torquing the head down which I have now done (I went middle of the specified range) following the Honda shop manual, an excellent resource on here thanks to the great forum members.  Should I retorque them tomorrow or will it be fine as is?
Getting the camshaft, sprocket and chain all on was a right b#####d, I knew I'd read Ted suggesting his method so trawled back through his build thread until I found his method.  All I can say is get the chain on the righthand side of the sprocket not the left then it's easy.
1975 XS650B
« Reply #507 on: March 06, 2024, 10:12:29 PM »
Glad you remembered my struggle with the cam chain - hard to put into words though.
Pleased it helped.👍👍👍
Online Bryanj
« Reply #508 on: March 06, 2024, 10:38:01 PM »
Honda dont specify retorque but might be an idea to take to the max setting after a 24 hour wait, in workshops we never did as time taken was always against us
Offline DomP
« Reply #509 on: March 06, 2024, 11:16:12 PM »
It really did help Ted, what didn't help was reading Ken mention to check and check again the tensioner is sat in its pocket in the crankcases...I'm panicking now even though I'm sure it was, any way of checking now its all torqued up?
I might do that Bryan but I felt uncomfortable torquing the two m6 flange bolts, makes me cringe doing them up in alloy to specified torque.
1975 XS650B
