Author Topic: Doms CB550F1 project  (Read 423452 times)
Offline DomP
Re: Doms CB550F1 project
« Reply #555 on: April 27, 2024, 08:41:45 PM »
That's the number I've tried Roo, it has never been answered just rings
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #556 on: April 27, 2024, 08:44:18 PM »
Mmm, maybe go all ninja and jump on em at 1 minute passed opening time on Monday and try to ambush them that way?       Swines!
« Reply #557 on: April 27, 2024, 09:40:13 PM »
I've bought stuff from them before and never had a problem. They're usually at the larger bike shows too.
« Reply #558 on: April 27, 2024, 10:59:51 PM »
Maybe just bad luck to have ordered from their site in the midst of a take over. I just tried phone number on their website Roo not sure if that’s the same one. I’ll give it a couple of days and try again.
« Reply #559 on: April 28, 2024, 02:00:50 AM »
Fingers crossed mate,
Offline DomP
« Reply #560 on: April 28, 2024, 09:14:41 AM »
I think when I order I'll just stick it on a credit card for safety
1975 XS650B
Offline DomP
« Reply #561 on: May 17, 2024, 06:12:22 PM »
Bleeding brakes!  This is getting annoying now, I've fitted a cbr600 master cylinder to my bike to fit my clip-ons and new braided line direct to the refurbed caliper but do you think I can get any pressure on the lever or movement of the piston in the caliper!
I've bled the mc end and everything I can think of to get fluid to pump through  so I'm at my wits end and asking for help here guys
1975 XS650B
« Reply #562 on: May 17, 2024, 08:02:58 PM »
Tie the lever to the bars and walk away for 24 hours and/or threaten to throw the f*▪︎kn thing out the window.
Worked for me at Meads
Offline DomP
« Reply #563 on: May 17, 2024, 08:31:36 PM »
Tried that Bryan😪
1975 XS650B
Offline DomP
« Reply #564 on: May 17, 2024, 08:47:33 PM »
I've got two other lines of investigation,  first is that I've used a banjo bolt on the caliper but I believe it is short enough that it doesn't bottom out on the caliper. Second is that the mc needs new seals but Roo thought it was rebuilt so I'm kinda assuming that much.
1975 XS650B
« Reply #565 on: May 17, 2024, 09:02:52 PM »
I might have stuffed you there Dom, I’ve checked my other ones and I put the kit into the one on the bike that’s on now‍
My heads a shed it appears, I might have a spare kit and off out to the Shed of Dreams in a bit, I’ll have a rummage
My bad!
Offline DomP
« Reply #566 on: May 17, 2024, 09:08:29 PM »
My bad!
It's moving fluid Roo, whether it's under enough pressure though I'm not sure
1975 XS650B
Offline DomP
« Reply #567 on: May 19, 2024, 07:25:28 PM »
I got there in the end, it took ages to get air out of the new master cylinder which was made harder because my clip ons have a 15° downward angle on them so air was sitting at the top slightly above the mc piston inlet.  Solved it by rolling the bike up the slope of my drive and putting it on the side stand.
Lesson learned!
1975 XS650B
« Reply #568 on: May 19, 2024, 09:49:04 PM »
Just got to work and was going to suggest standard bars might help
Offline DomP
« Reply #569 on: May 22, 2024, 01:37:40 PM »
I'm trying to fit my new Koso multifunction gauge and daytona speed sensor but have cone across a few queries.  First one, is there a permanent live in the headlight I can tap power from?
The three wires from the speed sensor don't correspond with the three from the gauge, they must be live signal and earth I presume but I've no way of knowing which is which on the koso side so any way of finding out would be great.
Then there is the rpm signal that I'm getting from the coil, the instructions are so confusing I don't understand what I'm meant to be doing here at all.
1975 XS650B
