Author Topic: Doms CB550F1 project  (Read 428779 times)
Re: Doms CB550F1 project
« Reply #630 on: July 05, 2024, 12:13:51 PM »
I remember during a metalwork class at school one of the kids was using auto feed on the lathe when he decided to go walkies. The resulting bang and carnage was a sight to see. The teacher went nuts and hit him over the head with a tool post!
« Reply #631 on: July 05, 2024, 01:41:29 PM »
At college we had a large cardboard chuck key that the last person to leave one in had to wear until the next person did it!
Offline DomP
« Reply #632 on: July 05, 2024, 08:03:30 PM »
I'll cut one out and where it tomorrow Bryan!
I'm not sure what the airbox lid brackets should look like exactly but here are my efforts complete with front and rear stamps because they ended up slightly different.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
« Reply #633 on: July 05, 2024, 08:56:50 PM »
On the subject of filter lids, looking at photos I think the mesh aperture is around 2mm, can anyone confirm for me as it will surely make a fair difference in air flow restriction.
1975 XS650B
Offline DomP
« Reply #634 on: July 11, 2024, 06:56:44 PM »
Is this distance correct, I've read there should be a measurement of 56mm between cable nipple and cable anchor point but the diagrams are near impossible to interpret.  What is the actual effect in real terms if the cables are not inder tension at idle?
The upper throttle stop screw into near to making contact with the bell crank
« Last Edit: July 12, 2024, 04:31:10 PM by DomP »
1975 XS650B
Offline DomP
« Reply #635 on: July 12, 2024, 04:44:40 PM »
I took my first real ride out lastnight just to see if any of the running issues might sort themselves out.  It seems to accelerate fairly well after bogging down a bit, the idle is the main problem though, it raises between gear changes and when coming to a standstill at junctions to the point I had to flick the kill switch on and off to settle it.  Other than that the front brakes are a bit woeful and I have a bobbly front end, could be a lack of wheel balancing or the oil weight maybe?
*oh and I hit 143mph, think I need to calibrate my speedo🤣
1975 XS650B
« Reply #636 on: July 12, 2024, 06:17:15 PM »
Nah, 143mph sounds about right Dom. I take it you didn’t get it in ‘top’ then?
Offline DomP
« Reply #637 on: July 12, 2024, 06:34:02 PM »
No not this time Roo, this was just through town on the back wheel.
I'm considering taking the carbs off do double check the float heights, jets are all clear and that I've set the bench sync to bottom out with the idle screw out, somethings not right to be running rich 2 1/4 turns out and have a idle that keeps rising with the throttle shut.
What do you think regarding the throttle linkage Roo?
1975 XS650B
« Reply #638 on: July 12, 2024, 08:03:45 PM »
On the 550 with the solid brass screw I thought the settings are 1/4 turn out as a base point. If you are over two turns out my understanding is that you have let so much air in it will be running  far too lean pulling fuel from the main jet when it can. Opening the screw slows down the amount of fuel from the idler jet so it's trying to  draw fuel from the main jet instead. Look at that video I posted about hanging throttles.
The 500 has a different design of air screw so needs more turns to achieve the same effect.
« Last Edit: July 12, 2024, 08:35:44 PM by McCabe-Thiele (Ted) »
Offline DomP
« Reply #639 on: July 12, 2024, 08:37:25 PM »
I believe on mine which are 069a's (550F1) the base setting is 1 3/4 turns out, if I richer it it stinks of fuel and soots up the plugs.  I'm happy to be wrong if it solves the hanging idle however 😄
Where the video Ted, worth a watch I think
1975 XS650B
« Reply #640 on: July 12, 2024, 10:19:37 PM »
It's under Misc/open on here Dom although the video shows  single cylinder bike his explanation seems logical - up to now no one has commented on the post.
Offline DomP
« Reply #641 on: July 12, 2024, 10:48:25 PM »
Oh I've watched that before, maybe I'm barking up the wrong tree then but the rich smell of fuel led me to think it needed leaning out not richening.  I'd say I have a climbing idle not a hanging idle though so I'll check for an air leak tomorrow
1975 XS650B
« Reply #642 on: July 12, 2024, 11:05:09 PM »
When altering the mixture on SU carbs on cars my late father told me the best guide to lean or rich was the exhaust temperature a rich mixture gives a cold exhaust out of the pipe , a lean mixture gaves a hot exhaust  - he never mentioned petrol smell.
« Last Edit: July 12, 2024, 11:21:34 PM by McCabe-Thiele (Ted) »
« Reply #643 on: July 12, 2024, 11:21:31 PM »
Just got home tonight axon, I’ll have a look tommoz, found a bottle of Landlord in the fridge and well that was that!
« Reply #644 on: July 12, 2024, 11:38:05 PM »
It might be I'm confused about the screw turns - it might be 1/4 turn for a 500 fitted with the 550 carbs.
I guess it's this table that you are refering to.
