Author Topic: Doms CB550F1 project  (Read 298998 times)
Online 3scs
Re: Doms CB550F1 project
« Reply #780 on: May 27, 2025, 11:29:44 AM »
Yours looks the same as my k3 Dom
« Reply #781 on: May 27, 2025, 11:53:46 AM »
Dom, the top right hand lug is the culprit. The top of the lug bracket should run parallel with the top of the frame, thus giving you the 15-20mm of misalignment you are experiencing. I appreciate that no two welds are the same, but yours has been re-welded imho. If other members could provide a photo of their their bracket positions this will become immediately obvious. That’s a bugger🤨
After seeing 3scs pics I tend to agree. Look at the angle of the hole between the 2 pics, 3scs has a slot sloping inwards, yours slopes outward.
Dom, where is your earth cable going from the battery? it's supposed to run downwards from the terminal and bolt to the upper engine hanger bolt, yours seems to be going towards the electrical panel under the left hand side panel. The positive cable doesn't look right either. I know you're running a MotoGadget wiring harness but that looks a little iffy to me.
« Last Edit: May 27, 2025, 11:57:30 AM by Oddjob »
« Reply #782 on: May 27, 2025, 12:00:10 PM »
Like dis…
Offline DomP
« Reply #783 on: May 27, 2025, 02:55:12 PM »
Do you think its in a k3 frame, come to think of it the riveted frame number looks like its been cut off and refitted.
Earthing Ken, it seems to have more than is necessary to me, no two ways about it, its been bu@@ered about with before I did my thing to it😅
Just as well I didn't get tge frame powdercoated and did a diy job on it with a brush I suppose, get the dremel out and lop it off is the only solution.  Get to try out my lack of welding skills again
« Last Edit: May 27, 2025, 03:10:13 PM by DomP »
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #784 on: May 27, 2025, 05:47:43 PM »
There are some differences between the F and K3 frames. The biggest difference is the swinging arm but it may not have that on anymore. Post a pic of the swinging arm and let's see if it's an F or a K3 one.
Did the frame come with a small plastic box near the coils, for all the switchgear wiring to go into?
Offline DomP
« Reply #785 on: May 27, 2025, 07:03:05 PM »
How's that Ken?
1975 XS650B
« Reply #786 on: May 27, 2025, 07:56:20 PM »
That top rear mout looks wrong to me, sure it should be orizontal
Offline DomP
« Reply #787 on: May 27, 2025, 08:09:40 PM »
That's just a perished old grommet that was fitted when I first got it, I'm now certain its the top right having been removed and welded back on in the wrong place, I'm not sure why it would have been though.
« Last Edit: May 27, 2025, 08:13:33 PM by DomP »
1975 XS650B
« Reply #788 on: May 27, 2025, 09:35:17 PM »
The swinging arm is 550F, the frame plate says it’s a 550F. Does the frame number correspond?
Offline DomP
« Reply #789 on: May 27, 2025, 10:46:00 PM »
I thought it was an F swingarm due to the closed ends, the frame number on the headstock is so painted over its illegible, I'll rub it back this week with my dremel
1975 XS650B
Offline DomP
« Reply #790 on: May 29, 2025, 07:49:13 PM »
Yesterday I flatted back the 2K lacquer and polished with my DA polisher, real quick way to get a mirror like shine and take a nick out of your freshly painted side cover when using one handed😤  luckily only small so I think I should be able to touch it in.
1975 XS650B
« Reply #791 on: May 29, 2025, 11:08:36 PM »
Without a front mudguard brace you will find the forks flex more. Maybe consider a fork brace that clamps around tge top of the sliders, that should suit the look.
« Reply #792 on: May 30, 2025, 03:51:51 PM »
Might have one Dom but no mudguard.
That looks ace Dom
Offline DomP
« Reply #793 on: May 30, 2025, 06:15:33 PM »
I might chop up my front mudguard and use it Ken, I'm not sure what i think of the mudguardless look quite but a trimmed down one will look good I think.
Thanks Roo, I might take you up on the offer, still got those yss shocks?
I meant to say, I cleaned up the headstock and it matches the frame number on the plate so definitely an F frame and correct, only solution is to cut the tab off and weld it back correctly, not looking forward to that!
« Last Edit: May 30, 2025, 06:18:27 PM by DomP »
1975 XS650B
« Reply #794 on: May 30, 2025, 08:38:39 PM »
Still got em Dom
