Author Topic: Doms CB550F1 project  (Read 428405 times)
Offline DomP
Re: Doms CB550F1 project
« Reply #810 on: June 21, 2025, 04:36:25 PM »
All standard Keihin jetting for 069a carbs Bryan, the air filtervis a standard F type but missing the rubber snorkel so I covered the hole in mesh but quite coarse.  I'll post a photo
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
« Reply #811 on: June 21, 2025, 04:38:34 PM »
Could this be too free flowing?
1975 XS650B
« Reply #812 on: June 21, 2025, 05:55:05 PM »
Doubt it, from what you describe its too rich.
That would give similar airfow to 500 which does have larger jets than 550
Offline DomP
« Reply #813 on: June 21, 2025, 06:09:47 PM »
Its better at 2⅛ to 2¼ turns out so do I just keep going until I get a good amount of rideability?  Its better but still has a significant flat spot at low revs then fly.
1975 XS650B
« Reply #814 on: June 21, 2025, 06:59:48 PM »
Cant answer that one sorry
« Reply #815 on: June 25, 2025, 03:55:20 PM »
Dom do all the jets bear the Keihin K logo?
I’m thinking someone has used a carb kit on your carbs in the past and the problem is the float needle valves and seat. A lot out there wouldn’t stop petrol flowing past if you held them against each other with your fingers. Lot of reports of the tip of the float needle being made off centre so fuel just leaks past, which would make the engine run rich as hell.
The only way to test is to remove a float bowl, turn on the petrol and use a float height setting tool set to 22mm and use that to lift the float, if the fuel stops when it reaches 22mm then it’s ok, if not then you have a problem. Container under the carb of course. I seem to recall genuine Honda float needles has rubber tips whereas copies just had steel tips. If it doesn’t stop at 22mm see if it stops at a higher setting, if it doesn’t stop at all then you need to replace that entire setup.
Offline DomP
« Reply #816 on: June 25, 2025, 05:19:13 PM »
All genuine jets Ken, I've stripped and replaced all orings etc in the carbs.
The float needles are fully metal, ie no viton tips so maybe worth replacing them, where can I get them as replacements?
« Last Edit: June 25, 2025, 05:47:41 PM by DomP »
1975 XS650B
Offline DomP
« Reply #817 on: June 26, 2025, 01:22:40 PM »
Nothing i can find suggests they were rubber tipped Ken, everything seems to be metal.
1975 XS650B
« Reply #818 on: June 26, 2025, 07:05:49 PM »
I'm a tad confused Dom, all this talk about the float valves?
Are the carbs flooding?
If not certainly worth ensuring the levels are correct.
Offline DomP
« Reply #819 on: June 26, 2025, 08:45:44 PM »
No flooding Ted, I think Ken was wondering if they were letting fuel through causing rich running as at 2¼ to 2½ turns think i might be a bit rich on some cylinders. No2 and 3 run quite a bit hotter on the exhaust headers
1975 XS650B
« Reply #820 on: June 27, 2025, 09:00:21 AM »
Are the carbs synched Dom, if 2 & 3 are a tad on the rich side or could it be float heights?
Do you suffer some hanging throttle issues?
« Last Edit: June 27, 2025, 06:37:50 PM by McCabe-Thiele (Ted) »
Offline DomP
« Reply #821 on: June 27, 2025, 05:29:04 PM »
Id like to think the float heights are correct now, I spent ages fettling them with vernier calipers, I do need to tweak the carb balance a bit so that might settle the 2/3 issue.  Hanging idle seems to be a thing of the past thankfully.
1975 XS650B
Offline DomP
« Reply #822 on: July 06, 2025, 02:14:19 PM »
I'm struggling to get some decent uninterrupted time on this at the moment, as it's a straightforward job and not time sensitive I thought I'd check my float heights on level ground, number 3 carb seems a little low but all others I believe to be good.  What is the effect of a slightly low float height?
What do you all think?  My carbs have a definite slope down towards the engine on the centre stand is this of significance?
« Last Edit: July 06, 2025, 02:16:42 PM by DomP »
1975 XS650B
Offline DomP
« Reply #823 on: July 06, 2025, 04:32:45 PM »
I've been out on a 15 mile run having balanced the carbs with a Carbtune about as close as I could get them.  Things I've noticed are the following-
Just a recap on the set up, 550f with genuine keihin jets and carbs set to factory.
•Still bogging down below 3k to the point I have to drop a get away
• top end seems to hit a bit of a wall at 5.5-6k but I am being careful due to the rebuild .
•the front suspension bounces like tigger at about 30-40 mph, I wonder olive ive used too light an oil so may replace with something a bit thicker.
Other than that at cruising speeds on main roads its very smooth
1975 XS650B
« Reply #824 on: July 06, 2025, 05:29:14 PM »
There is no power below 3,000 would be my comment, top end could be timing
