Author Topic: Doms CB550F1 project  (Read 423523 times)
Offline DomP
Re: Doms CB550F1 project
« Reply #825 on: July 06, 2025, 06:52:45 PM »
To the point it wont pull away Bryan?  Ignition is a Dyna S which ive set up statically with a test light following several YouTube videos, I'm sure its right having watched several different videos but happy to be wrong.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #826 on: July 06, 2025, 07:33:11 PM »
Personally would try it with original points, are you using the Honda coils or Dyna?
Offline DomP
« Reply #827 on: July 06, 2025, 09:37:26 PM »
I'm using Honda original coils that I've done Ash's fix on with new leads, it came with the Dyna so I don't have the original points.
1975 XS650B
« Reply #828 on: July 07, 2025, 06:51:52 AM »
I read recenrly somewhere the Dyna now say only use their coils, but then on us site also read of a lot of dyna failures
Offline DomP
« Reply #829 on: July 07, 2025, 08:10:03 AM »
I have read of a few failing, not sure which way to go now im beginning to loose patience a bit.  Time for a holiday i think!
1975 XS650B
« Reply #830 on: July 08, 2025, 08:39:29 PM »
My 750 has Dyna s and Original coils runs great!
Offline DomP
« Reply #831 on: July 08, 2025, 09:11:53 PM »
I have to admit I'm reluctant to remove it.  I need to read a comprehensive guide to carb tuning, I don't know whether in coming or going, rich or lean!  On one hand everything points to rich with sooty plugs and stinking of fuel then I lean it out to 2 ¼ turns out and I've got kangarooing at lower revs and bogging down but suddenly racing away once I hit 3k.  I'm not giving it fistfuls but feeding in the throttle.  I feel I'm close at times but my lack of carb knowledge leaves me confused.
1975 XS650B
Online Laverda Dave
« Reply #832 on: July 09, 2025, 01:14:49 PM »
Hmmm, recent Dyna failures. Dyna were a highly regarded name for ignition systems and coils. I wonder if this is maybe linked to manufacturing changes. Are Dyna still manufacturing in the USA or have they gone like all the rest and moved manufacturing to China?
Offline Rozabikes Tim
« Reply #833 on: July 09, 2025, 01:50:42 PM »
The "orange one" will some tariffs on them if so!!
Offline DomP
« Reply #834 on: July 13, 2025, 09:14:11 AM »
Could any of my rich running be related to me running a modified air box? Be ause mine had most of the recirculating parts missing I've plugged the airbox hoses and am running a 550k or maybe a 500 air filter without the hole in the bottom for the air breather.  The lid is from an F model as it should be but is missing the snorkel so I've just glued a stainless mesh over it.   I'd have thought this would all be less restrictive so if anything would tend towards lean?
1975 XS650B
Online Skoti
« Reply #835 on: July 13, 2025, 11:58:48 AM »
What sort of air cleaner cover do you have and what size jets?
Mines was bogging down and hesitating at lower revs, tried all the usual stuff such as air filter, pilot jets and mains.
Bloke at the moto piston rally in Spain with a high mileage F1 told me the needles and needle jets would need changing, he was correct it ran beautifully after that.
Skoti
1976 Honda CB750F1
Offline DomP
« Reply #836 on: July 13, 2025, 04:41:18 PM »
Getting new genuine needles and emulsion tubes, I'm not sure that's likely in the UK.
1975 XS650B
Online Skoti
« Reply #837 on: July 13, 2025, 05:24:46 PM »
I got a genuine set sent from Australia, then later a spare set from a Honda dealer in Sweden.
(But since then the've become available in the UK again)
I just looked up the part number on CMSNL and then google searched worldwide.
But of course 550F1 stuff maybe much more scarce.
Anyhow good luck.
Skoti
1976 Honda CB750F1
Offline DomP
« Reply #838 on: July 13, 2025, 06:27:46 PM »
Anyhow good luck.
Im not sure Skoti but I will certainly look into it, in the meantime I do wonder if this it too free flowing
1975 XS650B
« Reply #839 on: July 13, 2025, 06:58:18 PM »
More air should make it weak not rich
