Author Topic: Doms CB550F1 project  (Read 423525 times)
Offline DomP
Re: Doms CB550F1 project
« Reply #840 on: July 19, 2025, 07:09:16 PM »
What is an acceptable max temperature for the engine block? My manifolds are a little varying in temp using a temperature gun, 1, 2 and 4 seem to be low 70s where as no 3 runs a good 10°C hotter with the block measuring high 90s bar cylinder 3 again which i just got 120°C with my gun.  Seems a bit improbable to have such a gradient so close together.
Incidentally, doing a plug chop only no3 was close to the pale brown colour on the white insulator section.
*following this i decided to double check my dynamic timing which is looking spot but there is a but, and I think it may be interesting.  On 1 and 4 I cant get the timing light to flash consistently, thus has got me questioning the 1-4 coil or its leads.  Another observation is that when raising the revs from idle it gets to 2000/2200 they fly past 3k to 4 with literally no control, I cant hold 3k for love nor money.  Is this the switch from pilot to main jet causing problems?
« Last Edit: July 19, 2025, 10:03:16 PM by DomP »
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
« Reply #841 on: August 25, 2025, 04:18:46 PM »
Still d**king around with my carbs!  Can anyone help with this little conundrum, at idle I get a different reading across the four than at 3k for example, where one carb is lagging behind at idle, it is then ahead at say 3k?  See pics
1975 XS650B
Online McCabe-Thiele (Ted)
« Reply #842 on: August 25, 2025, 05:37:18 PM »
I'm no expert my thoughts are, at idle you are running on different fuel metering jets than when you are running at 3k with no real world load on the engine.
Offline DomP
« Reply #843 on: August 25, 2025, 05:41:28 PM »
That was my thinking Ted, if I then I each air screw individually that carb struggles so suggests the passages are clear or working, just that some carbs react more to throttle making syncing impossible
1975 XS650B
Offline Seabeowner
« Reply #844 on: August 25, 2025, 07:00:28 PM »
The manual only specifies measurement at low revs. Think it's a big ask to get it over a wide rev range.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline DomP
« Reply #845 on: August 25, 2025, 07:48:59 PM »
Its actually not as bad is I'd thought,  just not as close at 3k as at 1000-1200, still the revs are hard to raise slowly with the throttle without it leaping from 2500 up past 3500-4000.  I presume thats as the advance kicks in, the springs have been trimmed by a PO
1975 XS650B
