Author Topic: regulator/rectifier  (Read 1052 times)
Offline robsoa
regulator/rectifier
« on: August 11, 2023, 10:33:19 AM »
I am restoring a CB500k0 USA import.  I have fitted the David Silver electronic ignition and will be using a custom loom with a modern combined regulator/rectifier.  Retailers seem to be selling both 5 wire and 7 wire r/rs which they claim will be suitable for my bike.  Any advice on which version to go for would be appreciated.
Re: regulator/rectifier
« Reply #1 on: August 12, 2023, 09:53:39 AM »
Sorry for asking, but what is wrong with your regulator and rectifier now? These original parts are very reliable and usually outlive your bike.
« Reply #2 on: August 12, 2023, 10:08:40 AM »
I am a fan of electronic ignition but tbh I would also stay with original rectifier/regulator arrangement.
You mention a custom loom has that been designed for a combined  unit?  If that is the case is it not a matter of counting your wires?
Offline robsoa
« Reply #3 on: August 12, 2023, 02:04:16 PM »
The original wiring loom and electrics were unusable as a result of overheating / melting at some point in the past.
« Reply #4 on: August 12, 2023, 02:19:31 PM »
So when you say Custom you mean an aftermarket replacement so the wiring is original?
« Reply #5 on: August 12, 2023, 03:38:12 PM »
The regulator is mechanical and all mechanical things wear, the point faces can pit and go out of alignment or even stick together. Electronic is faster acting and more accurate. Both my reg and rec are good but I'll be replacing them both with a combined electronic reg/rec for those reasons. Try to find one that uses Mosfets
Offline robsoa
« Reply #6 on: August 12, 2023, 03:42:46 PM »
Loom will not be an aftermarket item, will be custom built to suit reduced electrics.  Any thoughts on whether r/r should be 5 or 7 wire type?
« Reply #7 on: August 12, 2023, 03:49:29 PM »
Go with 7 if you can find it. Easier to understand how it wires in that way.
Offline robsoa
« Reply #8 on: August 12, 2023, 03:52:16 PM »
Thanks for the advice :)
