Author Topic: Do I have the wrong cable  (Read 5293 times)
Offline gary123
« on: August 12, 2023, 03:54:43 PM »
There's way to much slack for the adjusters to cope with.
Re: Do I have the wrong cable
« Reply #1 on: August 12, 2023, 04:50:38 PM »
Looks like you've got the longer type USA cable for the higher bars Gary. Is the top end routed correctly?
« Reply #2 on: August 12, 2023, 04:59:15 PM »
Is that a 500 cable you are using?
Might be worth checking the uncovered cable length to compare.
Unless the US version has a different lever I would expect the extra length to just leave a loop of spare cable.
Can you move the lower bracket higher or is that fixed?
« Last Edit: August 12, 2023, 05:08:28 PM by McCabe-Thiele (Ted) »
« Reply #3 on: August 12, 2023, 05:32:35 PM »
Looks more like a cb750 K cable  ;) You will need a 550 cable as you have a 550 cover  ;)
Offline gary123
« Reply #4 on: August 12, 2023, 05:47:17 PM »
I could well be wrong but I thought a slight difference in overall length wouldn't matter. as its the free inner cable length that is important.
On this cable it is 5.5 inches which is quite a bit to much for the adjusters to cope with.
I also thought 500 and 550 cables were the same.
Offline gary123
« Reply #5 on: August 12, 2023, 05:48:01 PM »
Bracket is fixed.
Offline gary123
« Reply #6 on: August 12, 2023, 05:49:27 PM »
Not routed as just a trial to see if the 550 conversion is working out.
Offline gary123
« Reply #7 on: August 12, 2023, 05:51:44 PM »
I was told its a 500 cable, then again I was told a lot of things that turned out to be "inaccurate" :o
« Reply #8 on: August 12, 2023, 05:55:02 PM »
500 cable has a cover over the adjuster bolt, 550 doesn't.
Offline gary123
« Reply #9 on: August 12, 2023, 06:21:46 PM »
Yes, it has a cover for the adjuster.
Offline gary123
« Reply #10 on: August 12, 2023, 06:25:25 PM »
Im thinking snip the nipple off and re solder (or solderless nipple)
« Reply #11 on: August 12, 2023, 06:28:24 PM »
That is what i would do mate, but use a solder nipple as, they are stronger  ;)
« Reply #12 on: August 12, 2023, 06:31:22 PM »
If you are going to East Kirkby bike night on Wednesday, you can take one out of my hand  ;)
Offline gary123
« Reply #13 on: August 12, 2023, 06:45:29 PM »
May well be there, whether permitting. The last one was packed, never seen so many bikes outside of a BSB bike park. Ill let you know.
« Reply #14 on: August 12, 2023, 06:49:18 PM »
The forecast is good but, the Bullshiting Broadcasting Company are not to be trusted  ;)
