Author Topic: Strobe Timing Light  (Read 9368 times)
Offline Matt_Harrington
Strobe Timing Light
« on: August 13, 2023, 12:54:32 PM »
My Sun strobe timing light has given up the ghost!  :'(
Any recommendations for a replacement - (I use one on my cars as well...) ?
Re: Strobe Timing Light
« Reply #1 on: August 13, 2023, 01:38:49 PM »
Not a recommendation just one to avoid.
I have a Clarke so called High Beam Timing Light model CHBTL1 it is a powered type that I run off a slave car battery.
It works but the leads are quite short, it would probably be useless outside as it's not really that bright, it's ok in my garage.
« Reply #2 on: August 13, 2023, 02:00:42 PM »
Yes, I remember years ago having one that wasn't even powered - absolute rubbish! Being able to see the light is fairly important!!
« Reply #3 on: August 13, 2023, 02:03:23 PM »
I have had a Accuspark  S8000 for years now, does the job  ;)
« Reply #4 on: August 13, 2023, 05:41:59 PM »
Thanks Graham, Certainly cheap enough.  ;D
« Reply #5 on: August 13, 2023, 07:01:48 PM »
Just looked it up, yes it is a lot cheaper than when i bought mine about 10 years ago so, an old model these days  ;)
