Author Topic: Brake pipe search. Help..!!  (Read 1544 times)
Offline Mick550
« on: August 13, 2023, 07:22:29 PM »
I know many men don’t seek a shorter pipe, but mine is such a case.
I have a 550K1, that I have fitted with lower bars. This is due to me being a short arse, and the tall ones feel like ape hangers. (We all know that riding with ape hangers means you soon find yourself on a slippery slope towards a long beard and tassels on your leathers, and I don’t want that)
I’m looking for a shorter top brake hose, which is drawing a blank, with the only possible close one so far being for a 350.. :
https://predatormotorsport.co.uk/Honda-CB350Four-1972-74-Front-Brake-Hose-Upper/
Is this the right one does anyone know, or from where I can get the right one?
Cheers.
Re: Brake pipe search. Help..!!
« Reply #1 on: August 13, 2023, 07:32:37 PM »
Not sure the one in the link will work, as I've never tried but have you tried looking for a 550K3 UK model one, or even EU model, as they both came with the lower Euro style bars as standard.
https://www.cmsnl.com/honda-cb550k3-four-england_model14671/partslist/
« Reply #2 on: August 13, 2023, 07:32:53 PM »
Measure the length and get a stainless one made, its only a banjo fitting on each end.
You can even by the hose and fittings on ebay and make your own its not difficult
« Reply #3 on: August 13, 2023, 11:10:16 PM »
Cheers.
If you have standard 500 or 550 UK bars, i have a new set of brake hoses that are for sale  ;)
The CB350 four is a USA bike and has high bars .
« Last Edit: August 13, 2023, 11:17:35 PM by Trigger »
Offline Mick550
« Reply #4 on: August 15, 2023, 08:55:35 PM »
PM sent Trigger, just as I was poised to follow Brianj’s advice... :)
« Reply #5 on: August 15, 2023, 09:48:41 PM »
This is the new set i have with a 390mm top hose Mick .
Offline Mick550
« Reply #6 on: August 16, 2023, 09:39:03 AM »
390 is what’s on there, difficult to measure as takes a meandering path on its way to the junction thingy. Maybe then this is normal and already the correct length..?
« Reply #7 on: August 16, 2023, 10:17:49 AM »
That looks like the correct length for european low bars  ;)
Offline Mick550
« Reply #8 on: August 16, 2023, 12:33:29 PM »
Ok cheers Trig. I thought it was a little taut with the high bars it came with, explains why.  :)
« Reply #9 on: August 16, 2023, 01:49:24 PM »
Mick, I've replied to the PM you sent me.
« Last Edit: August 16, 2023, 03:55:46 PM by Nurse Julie »
