Author Topic: Exhaust stud  (Read 4718 times)
Offline toucheturtle
Exhaust stud
« on: July 29, 2010, 12:02:42 PM »
Hi,
One of the exhaust studs on my cylinder head is loose. I can tighten it in but when I come to fit the exhaust and tighten the nut it only tightens so much and then slowly starts to pull the stud out.
Is there a product which will fix the stud in place? The problem isn't serious enough yet to warrant drilling the hole out and tapping a larger stud. If it was at all possible I'd like to keep all the studs and nuts the same size.
Offline totty
Re: Exhaust stud
« Reply #1 on: July 29, 2010, 12:10:56 PM »
Sounds like it needs a thread insert, helicoil are probably the best known.
