Author Topic: Cylinder stud  (Read 3301 times)
Offline Fraser McGillivray
Cylinder stud
« on: August 15, 2023, 04:12:46 PM »
Hey guys.....Anyone willing to part with one small 158mm cylinder stud. Had a bit of a misfortune earlier and sheared the last stud clean off. I`m rebuilding a 750 K8.
Regards....Fraser
Re: Cylinder stud
« Reply #1 on: August 15, 2023, 05:07:32 PM »
Hi Fraser, and welcome to the forum. Bit of a bummer that broken stud, has it snapped flush with casing? There’s certainly people on here that have done a lot of these engines so there is a chance you may be lucky. Good luck with the bike and the repair.
Re: Cylinder stud
« Reply #2 on: August 15, 2023, 05:18:04 PM »
Cheers Johnny....it sheared roughly 3mm above the flush and on inspection there was a slight flaw in the stem, so it was def` going to shear. I did manage to get the threaded part out with heat, drill and an ease out with no damage to the case threads, so all`s well in that respect but hoping someone will have bits and pieces lying about as i`m struggling to find one anywhere, even CMS Spares in Holland....
Re: Cylinder stud
« Reply #3 on: August 15, 2023, 05:44:06 PM »
That’s great you got the piece of stud out with cases intact. Give it a little time see who comes along with assistance. 24 hours or so would be reasonable.
Re: Cylinder stud
« Reply #4 on: August 15, 2023, 05:45:31 PM »
I'll ask Graham later if we have any spares. But, I don't know if the ones we may have, which would be from K0, K1 and K2, are the same as the K8 🤔🤔🤔
Re: Cylinder stud
« Reply #5 on: August 15, 2023, 06:17:32 PM »
Hi Fraser. Before I get Trigger rummaging in the in the depths of the workshop, can you confirm its part number 90034-300-030?
Re: Cylinder stud
« Reply #6 on: August 15, 2023, 06:20:55 PM »
Thanks Julie.....As far as i`m aware the Studs are the same through all years. On my search earlier i came across ARP studs and on their packaging they claim 69 to 78 so they don`t seem to thing there`s variation so hopefully thats the case.
Re: Cylinder stud
« Reply #7 on: August 15, 2023, 06:23:11 PM »
Thats the one Julie.....The short one at 158mm
Re: Cylinder stud
« Reply #8 on: August 15, 2023, 06:38:23 PM »
How many do you need, mainly long ones in this box but found a good straight short one, 😁😁😁😁. I'll send you a PM.
Yes, we've got that one
Re: Cylinder stud
« Reply #9 on: August 16, 2023, 11:30:19 AM »
Hi Julie....just reqire one short one......you can email me at frasermcgillivray@ yahoo.co.uk
