Author Topic: Crankcase Breather  (Read 6951 times)
Offline Neill C
Crankcase Breather
« on: August 19, 2023, 06:23:43 PM »
Hi all. I've 1500 miles since having an engine rebuild and have a small amount of oil coming out of the crankcase breather. I think this only happens after I've ridden it at higger speeds than normal. Is this something to worry about?
Re: Crankcase Breather
« Reply #1 on: August 19, 2023, 07:11:11 PM »
Check the oil level correctly to start with. It should be just fumes coming out of the breather but raised crank case pressure could cause oil to come out.
« Reply #2 on: August 19, 2023, 07:21:36 PM »
No, normal.
Offline Neill C
« Reply #3 on: August 19, 2023, 07:50:45 PM »
Thanks guys. I'll check the oil level in the morning.
« Reply #4 on: August 19, 2023, 09:41:48 PM »
If you keep the oil level somewhat lower than MAX, you will see less oil coming out of the breather tube.
« Reply #5 on: August 19, 2023, 11:51:43 PM »
The rebuilt engine requires a full service after 500 miles run in period and you would of noticed if it was low then.
You should not have any oil coming from the breather unless the engine is old and high milage. Was the piston to bore clearance correct at the time of rebuild ?
« Reply #6 on: August 20, 2023, 06:50:22 AM »
I think we have to distinguish between oil pouring and tiny oil spats. The latter I have always had after hot rides for 43 years.
Offline Neill C
« Reply #7 on: August 20, 2023, 07:35:56 AM »
The rebuild was carried out by a classic Honda specialist and had a rebore with larger pistons so I assume they are OK. The oil isn't pouring out. Just enough to wet the end of my finger
« Reply #8 on: August 20, 2023, 08:01:04 AM »
A little oil can depend on a lot of things, including the grade of oil in the engine. If you have drips on the deck, i would suspect that it was not rebored to the correct spec .
Offline Neill C
« Reply #9 on: August 20, 2023, 12:58:47 PM »
Assuming that is correct and I can't go back to the garage that did it as it was 3 years ago now and seeing as I only use it for coffee and chip shop runs should I just live with it?
« Reply #10 on: August 20, 2023, 01:47:10 PM »
I wouldn't loose any sleep over it if you hardly ever use it. But, it may have an issue that will get worse.
Offline Neill C
« Reply #11 on: August 20, 2023, 05:59:10 PM »
Thanks. I did check the oil and its up to the top on the dip stick(when unscrewed) and would could even go slightly over. It depends on how level I think the bike is when checking it. How do you get it perfectly level in the first place?
« Reply #12 on: August 20, 2023, 06:04:13 PM »
Its normaly checked on the centre stand  with dipstick just resting on threads, the difference in angle for the bike to be able to sit on centre stand on slope should make little difference , in theory but we all know about theories!
Most import thing is to check it same way every time so you can see if you are using any
« Reply #13 on: August 20, 2023, 09:54:55 PM »
Something about that statement worried me, I presume you mean up to the top of the markings on the stick not to the top of the stick itself. Also check cold not hot.
Offline Neill C
« Reply #14 on: August 21, 2023, 06:22:43 AM »
Yes. Up to the markings and stone cold.
