Author Topic: Picture sought of right side behind side panel.  (Read 3458 times)
« on: August 21, 2023, 07:18:39 PM »
Amongst my many photos that I took when dismantling my 500 I failed to take one of the right side with the side panel removed showing the battery box etc.
Does anyone have a picture I could use for reference purposes please?
Re: Picture sought of right side behind side panel.
« Reply #1 on: August 21, 2023, 07:33:41 PM »
I can do one tomorrow,
Tell me what you need
« Reply #2 on: August 21, 2023, 07:54:08 PM »
Thanks John it's mainly the position of the battery box mounting please in particular what does the bottom right battery box bolt fit into?
« Last Edit: August 21, 2023, 11:25:50 PM by McCabe-Thiele (Ted) »
« Reply #3 on: August 21, 2023, 07:54:09 PM »
This is from my K2 Ted.
Sent from my moto g(50) using Tapatalk
« Reply #4 on: August 21, 2023, 08:30:47 PM »
That will do thanks.
So the top left bolt fits through the rubber mounting with the support tube in place then bolts into the lug on the frame.
The lower right bolt passes through the mounting rubbers but there appears to be no support bracket for the end?
« Last Edit: August 22, 2023, 08:56:18 AM by McCabe-Thiele (Ted) »
« Reply #5 on: August 23, 2023, 09:18:42 AM »
Sorry, only just seen your reply. Out at the moment so I'll have a look later
« Reply #6 on: August 23, 2023, 10:50:06 AM »
It's okay Phil there is no bottom bracket it just bolts up with a large end washer info from Ken.
