Author Topic: Clutch basket rubbers  (Read 9424 times)
Offline Matt_Harrington
« on: August 27, 2023, 03:43:44 PM »
I see we have someone flogging these on ebay - anyone tried them or make any comments?
Re: Clutch basket rubbers
« Reply #1 on: August 27, 2023, 05:05:49 PM »
Do you have a link or item number?
Offline XS850
« Reply #2 on: August 27, 2023, 05:53:19 PM »
EBay item # 155739423238
Cheers - Bruce
« Reply #3 on: August 27, 2023, 06:41:14 PM »
Not a very good seller. 3 items in 2 years. He will be a millionaire by the end of the year  ;D ;D ;D
« Reply #4 on: August 27, 2023, 06:45:51 PM »
Possibly a forum member 🤔🤔🤔. Good luck to the seller though, there is a sizeable UK market for them.
« Last Edit: August 27, 2023, 06:49:03 PM by Nurse Julie »
amx1992
« Reply #5 on: August 27, 2023, 07:16:05 PM »
Thats me, i made these a few months ago, and I've been testing them out for the past couple of months to make sure im happy with them. Trigger ive got another account but ive just started using this account for stuff ill need to pay tax on to make my accounting a bit easier
« Reply #6 on: August 27, 2023, 07:21:13 PM »
You say in the listing that the 400 has 2 types. I have only found one type in a 400 and in your picture "B" is the 500/550 type  ;)
amx1992
« Reply #7 on: August 27, 2023, 07:24:58 PM »
Thats interesting, both baskets came from 400 engines, and oddjob posted a pic of a 550 one and it was completely different to both. Do you have any pictures of 500 ones? Also do the 500 baskets fit the 400?
« Reply #8 on: August 27, 2023, 07:28:34 PM »
I have had a few 500 baskets done in germany and the shape is the same >>> https://www.fourever-classic-parts.de/index.php?option=com_content&view=article&id=26&Itemid=31
amx1992
« Reply #9 on: August 27, 2023, 07:32:10 PM »
If those ones in the link are 500 ones, they are the same as oddjobs 550 ones, but aren't the same as the one on my ebay photo
« Reply #10 on: August 27, 2023, 07:38:11 PM »
Your ad says there are two types of 400 cush rubbers, there is only one type, which I'm very familiar with. The 400 cush rubbers will not fit the 500 or 550 and vice versa as they are different clutch baskets. If I remember correctly, the 500 and 550 rubbers are the same, even though the baskets are different.
« Last Edit: August 27, 2023, 07:40:29 PM by Nurse Julie »
amx1992
« Reply #11 on: August 27, 2023, 07:42:47 PM »
Well both those rubbers came from baskets from running 400 engines, and they aren't 500 or 550 ones
« Reply #12 on: August 27, 2023, 07:45:14 PM »
OK, so one of the 400 baskets had the wrong cush rubbers fitted, there is definitely only one type for a 400.
amx1992
« Reply #13 on: August 27, 2023, 07:47:06 PM »
The rest of the basket is completely identical, but the aluminium posts are a different dimension and the holes in the gear are smaller, and it was still factory rivetted. If the 400 rubbers fitted it wouldn't be a problem.
« Last Edit: August 27, 2023, 07:49:32 PM by amx1992 »
amx1992
« Reply #14 on: August 27, 2023, 07:48:17 PM »
Could it have been a 350 clutch basket?
