Author Topic: I suspect Ken is right about the quality of Gerben work look at my 500 carbs!  (Read 10133 times)
Online florence
Re: I suspect Ken is right about the quality of Gerben work look at my 500 carbs!
« Reply #30 on: September 21, 2023, 03:43:17 PM »
no worries, I can always save it in case I need it.  It nearly ended up in the scrap but now thinking should keep just in case.
« Reply #31 on: September 21, 2023, 04:59:11 PM »
If you want to sell that incomplete set of carbs Florence let me know. I presume they are 627B?
I have the parts to complete them so I might be up for a little project.
Online florence
« Reply #32 on: September 22, 2023, 12:52:30 PM »
Sorry Ken, I imagine they are no good for restoration, the aluminium of the carb bodies at the inlet on two of them has corroded very badly indeed.  I am not sure how, they came like that in a job lot of spares.  Strangely the throttle mechanism is in very good condition, even the chrome part but as I said the carb bodies are scrap.  Luckily the float chambers are good and I have already needed to fit two of them to my bike as every now and again the brass tubes split, probably down to ethanol in the fuel.
Online florence
« Reply #33 on: September 25, 2023, 03:01:52 PM »
Pm sent
Online florence
« Reply #34 on: September 25, 2023, 03:11:09 PM »
Not as good as I thought
« Reply #35 on: September 25, 2023, 05:06:05 PM »
Hi Florenece I will PM you - what is the loose metal collar on the shaft  in the second photo?
Online florence
« Reply #36 on: September 26, 2023, 11:05:22 AM »
not sure, just part of the setup
« Reply #37 on: September 26, 2023, 02:07:28 PM »
It's not meant to be on there. It looks like the cap on the lifter arm, the one that covers the felt washer.
I've just assembled Carb:1 the float level was 22 mm as per the manual.
On  taking Carb:2 to bits today I was surprised to find silicone type sealant was used both on the carb top gasket and for the fuel bowl O rings.
Not by me
I know that Bryan the work was done by Gerben, I was surprised that they would use an adhesive when there is no need unless it's belt & braces to avoid returns.
As my Dad used to say a firms reputation is only as good as their worst mechanic.
Good bit is the bowls and top were easy to shine up again. Quite a few of the bowl screws were rusted so I've used SS replacements.
Stranger & stranger all my 500 needle circlip positions are set at the second groove from the bottom - richer than the standard center circlip position 3 out of the 5 grooves.
