Author Topic: Fitting oil seals  (Read 3016 times)
Offline DomP
Fitting oil seals
« on: September 30, 2023, 04:32:50 PM »
On reassembly of my crankcases should I put a very thin smear of Hondabond on the oil seals that aren't on the case half joints ie selector drum seal?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: Fitting oil seals
« Reply #1 on: September 30, 2023, 04:56:26 PM »
I would not just makes it harder to remove in the future.
A smear of Red Rubber grease works for me.
« Last Edit: September 30, 2023, 06:21:48 PM by McCabe-Thiele (Ted) »
Offline DomP
« Reply #2 on: September 30, 2023, 06:34:23 PM »
That was what I wondered but I've seen on some builds where they've been hondabonded but I might be thinking of all the seals that intersect the case halves.
1975 XS650B
« Reply #3 on: September 30, 2023, 07:26:51 PM »
I used a smear of Hondabond on the crank seals & the bearings to keep them in position laterally.
« Reply #4 on: September 30, 2023, 08:29:06 PM »
Goop on seals held by clamped cases, grease on pushed in ones
Offline DomP
« Reply #5 on: September 30, 2023, 09:04:09 PM »
Cheers Bryan, see you tomorrow!
1975 XS650B
