Author Topic: Flooding carb..  (Read 3796 times)
Offline Athame57
Flooding carb..
« on: October 05, 2023, 03:25:20 AM »
One of my carbs has been flooding, ie the overflow leaking. This I can stop by tapping the thing with a spanner a while, but what should I really be doing?
1978 CB400F2 named Elen.
Re: Flooding carb..
« Reply #1 on: October 05, 2023, 07:00:52 AM »
I find rocking the bike from side to side off the stand works just as well as tapping the float bowl.
If the bike is used regularly it could be some dirt in the float valve or sticking of the float mechanism. If the bike is only used occasionally then might be old fuel or fuel residue gumming things up in the fuel bowl due to evaporation.
Offline DomP
Re: Flooding carb..
« Reply #2 on: October 05, 2023, 07:20:09 AM »
Or is the float set to high?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline Athame57
Re: Flooding carb..
« Reply #3 on: October 05, 2023, 08:52:23 AM »
I think I'll go back and check, it is only recently I overhauled the carbs and fitted viton rings.
Offline TrickyMicky
Re: Flooding carb..
« Reply #4 on: October 05, 2023, 09:00:57 AM »
I had this problem after the bike had been stood unused for a few years. After a couple of knuckle skinning episodes of removing/replacing carbs I finally stumbled upon the most simple (obvious?) cause, the floats were not moving very freely on the little brass spindles which had accumulated a nice coating of gunge!.  Remove spindles, 30 minutes careful polishing with ultra fine emery, replace carbs and no leaks. Sit back feeling rather pleased whilst opening yet another packet of Elastoplast.  I have owned my 400 for nearly 36 years now, and it's still my favourite one to ride,BUT, when it was designed I think Mr. Honda must have had an evil glint in his eyes, and assembled the carbs, rubber bits, and airbox, hung them on a bit of string and then built a motorcycle round them. Good fun though, eh?  Stay safe. Mike.
