Author Topic: CB750F1 starter issue - heeelp!  (Read 3087 times)
Offline Priddy
« on: October 09, 2023, 02:52:27 PM »
Looking for a bit of help here, my F1 has started to not restart if stalled in gear. I've gone through the wiring testing all and fitted a solenoid, all indications are that the wiring is fine. Bike starts and runs fine but will ONLY start on the button if in neutral.
Any clues would be appreciated (P.S. neutral light works fine) - Thanks in anticipation!
Martyn Priddy
Re: CB750F1 starter issue - heeelp!
« Reply #1 on: October 09, 2023, 02:55:37 PM »
I know nothing about F1's but do they have a clutch lock out switch fitted?
Edit... Yes, they do.
« Last Edit: October 09, 2023, 02:58:35 PM by Nurse Julie »
« Reply #2 on: October 09, 2023, 03:06:43 PM »
Is it a USA spec bike with the safety unit.
Offline Priddy
« Reply #3 on: October 09, 2023, 03:17:01 PM »
I don't think its a US spec, UK as far as I know!
Martyn Priddy
« Reply #4 on: October 09, 2023, 03:24:58 PM »
Have you got a photo of the electrics behind the side panel.
Offline Priddy
« Reply #5 on: October 09, 2023, 03:32:54 PM »
Further checks do point to the clutch switch! never underestimate the obvious.
Thanks for replies i'll get one ordered!
Martyn Priddy
