Author Topic: Rusty tank restoration  (Read 8863 times)
Offline Siloxious
  • CB500 Four - General Export K1
« on: October 14, 2023, 12:32:02 PM »
Hello everyone
I'm currently restoring the fuel tank (inside). I filled the whole tank with white vinegar and let it sit for 48 hours. The results are quite good. But now I need to treat the aluminium against corrosion. I plan on using WD-40 to coat the inside of the tank (I plan on using a lot of WD-40). After soaking for a bit, I'll fill the tank again with fuel (I think the best fuel for the CB500 Four is E95?).
Is the WD-40 a good protection against corrosion?
Is this the right fuel that I'll be using?
Thanks in advance!
Offline Orcade-Ian
    • Older Vehicle Web
Re: Rusty tank restoration
« Reply #1 on: October 14, 2023, 01:17:48 PM »
Er,
Which bits are aluminium?  Whatever you put in the tank will get washed away with the fuel fairly quickly.  If it's just for storage, then diesel swished around is better.  Those pits in the surface look quite deep.  When you have finished cleaning, I would fill it with petrol before any painting, just in case of pin holes appearing.
Ian
Did you mean E5?  Here in UK we only have E5 and E10
« Last Edit: October 14, 2023, 01:23:43 PM by Orcade-Ian »
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline Siloxious
« Reply #2 on: October 14, 2023, 01:55:32 PM »
Here in Belgium E95 is used a lot in cars, so I thought this could be the same fuel type for motorcycles.
What fuel do you use?
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #3 on: October 14, 2023, 02:06:25 PM »
Ah!
I think you will be referring to 95 Octane fuel, that is also available here.  E5 here is 5% ethanol content, E10 is 10%.  We would run a mile - or a few kilometres if we saw E95 on the pumps - that would be 95% ethanol and our old Honda engines would probably dissolve before our eyes!
Ian
1972 Honda CB 350/4
2026 Honda ADV 350
« Reply #4 on: October 14, 2023, 03:52:09 PM »
The tank on my 400 was similar to yours - I would use something like a fine gravel now with some Diesel to act as a mild abrasive to remove any loose flakes of rust. I actually used some flower arrangers glass beads. When you have removed the gravel I would soak it again in something similar to Evaporust.
« Last Edit: October 15, 2023, 08:21:36 PM by McCabe-Thiele (Ted) »
« Reply #5 on: October 16, 2023, 11:03:22 PM »
Use Bilt hamber  diox c and fish tank gravel. Use hot water to make the solution and agitate every 6-8 hours over a 24 hour period. Rinse with de-ionised water and flush with a pint of diesel.
« Last Edit: October 17, 2023, 08:04:02 AM by Sesman »
Offline DomP
« Reply #6 on: October 17, 2023, 07:29:01 AM »
I did mine with a mix of electrolysis and phosphoric acid, I'm not entirely happy leaving it bare but everything I read about liners puts me off them
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #7 on: October 17, 2023, 09:25:57 AM »
Bilt hamber  diox c
What does that mean Phil?
Offline Athame57
« Reply #8 on: October 17, 2023, 09:35:04 AM »
Bilt hamber  diox c
I googled and got this: https://bilthamber.com/product/deox-c/
1978 CB400F2 named Elen.
« Reply #9 on: October 17, 2023, 12:29:35 PM »
I used deox-c in my tank for 24 hours and it came up really clean. 👍
« Reply #10 on: October 17, 2023, 06:39:16 PM »
That’s the stuff. Works really well.
« Reply #11 on: October 18, 2023, 01:07:25 AM »
Tip noted, cheers chaps, I’ve to sort the 550 tank out before I send it in for paint.
 I’m in the states from next Thursday until late December so going to tackle it when I get back.
I was going to go the vinegar route but this gubbins sounds just the job. Is there a specific recipe for a 550 tank, eg. Can I do it with one tub? Just so I order enough to be here waiting for when I get back?
« Reply #12 on: October 18, 2023, 01:12:06 AM »
Just found the recipe page on the website, please disregard last message
Offline Matt_Harrington
« Reply #13 on: October 18, 2023, 06:30:07 PM »
Roo, I've found Evaporust great at removing rust from the inside of a tank.....
If the tank is pitted, I'd be tempted to seal with tank sealant.
Send us a postcard!
« Reply #14 on: October 18, 2023, 06:35:48 PM »
It’s not that bad Matt with little putting, it’s about the only bit of the bike I lucked out on
I’d love to use evaporust but it’s a bit cost prohibitive tbh. This gubbins described earlier has a good right up and I can do the tank from top to bottom for 16 quid so it’s looking favourable. It would cost about £50 to do the same with the evaporust. I do use it but only on bits n bobs. How’s the hand doing, you managing a yet ?
