Author Topic: Rusty tank restoration  (Read 8861 times)
Offline Matt_Harrington
Re: Rusty tank restoration
« Reply #15 on: October 18, 2023, 06:40:57 PM »
I'm just about ready to try my hand a thumbing a lift! ;) Seriously, its much better and should be on 2 wheels soon!
The other stuff to try is oxalic acid - I have some you can have on your return
« Reply #16 on: October 18, 2023, 06:43:33 PM »
Ooo, I’ll have a read on’t interweave and come back to you bud……Fanks mate.
Top news about yer paw,  be nice to get you back out and rolling
« Reply #17 on: October 18, 2023, 07:00:13 PM »
Might be tank sealers have improved over the years but I'm not a fan. When I tried it on my XJ900 it still leaked - ended up buying a new tank.
« Last Edit: October 18, 2023, 08:30:51 PM by McCabe-Thiele (Ted) »
Offline Athame57
« Reply #18 on: October 18, 2023, 08:30:16 PM »
I used deox-c in my tank for 24 hours and it came up really clean. 👍
What size did you need to use?
1978 CB400F2 named Elen.
« Reply #19 on: October 18, 2023, 08:35:23 PM »
Citric acid is the main ingredient in Deox-c. We've used citric acid dissolved in boiling water on a few occasions, with excellent results on fairly rusty tanks. It's very cheap to buy on ebay.
« Reply #20 on: October 19, 2023, 08:34:50 AM »
The 1kg pot is all you need….£16
« Reply #21 on: October 19, 2023, 11:31:50 AM »
Exactly. If I remember right it can make up a 20 litre solution. I didn't have a big enough container to do it in one go, so dissolved half the tub in a large clean bucket, poured it in the tank, then did the second half. Fill the tank to the brim, close the cap and leave it. Just agitate/rock the tank every now and again.
It's worth getting a large container to keep the solution in when you're finished, it can be used again several times.
« Reply #22 on: October 19, 2023, 06:29:18 PM »
Ordered, thanks fella’s et all
Offline Seabeowner
« Reply #23 on: October 19, 2023, 06:41:01 PM »
Make it up as hot as possible. I used it as part three of my cleaning. Insulated the tank to keep it as hot as possible and it was all over in 5hrs.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #24 on: October 19, 2023, 09:24:10 PM »
Good tip, cheers for that
