Author Topic: Chain surface rust question?  (Read 3385 times)
« on: October 26, 2023, 10:59:30 AM »
My 500 clearly had some damp or rain exposure as this is the chain that was new about 2 years ago now - it has covered less than 50 miles.
The outside part of the chain has surface rust, the inside is almost rust free - is it worth cleaning it up & using it?
I guess the blue appearance of the chain will be gone once I remove the surface rust with rust remover.
It's more of a safety question than cosmetics - I have new sprockets.
.side b by Macabe Thiele, on Flickr
.side a by Macabe Thiele, on Flickr
Re: Chain surface rust question?
« Reply #1 on: October 26, 2023, 11:19:38 AM »
No problem at all. Clean it with some lampoil, kerosene, WD-40, whatever. Or with a steelbrush first. If you really want a chain with good looks, order a nickel plated one next time. ;)
« Reply #2 on: October 26, 2023, 11:42:48 AM »
I presume it’s not an oring chain. If so, give it a good clean and lube.
« Reply #3 on: October 26, 2023, 03:13:01 PM »
Throw it in a bucket of your favorite stuff and let that eat the rust Ted. Won't hurt that type of chain.
« Reply #4 on: October 26, 2023, 11:30:24 PM »
Put it in the dishwasher, Ted😁😁
« Reply #5 on: October 27, 2023, 04:17:56 PM »
« Reply #6 on: October 28, 2023, 04:37:16 PM »
If all the links are moving freely, no stiff links,  then good to use. Spray the light surface rust with ACF50 then wipe off the excess.
