Author Topic: 650 cam swap for cb550k3  (Read 8435 times)
Offline captaindonutbikes
« on: August 12, 2010, 12:39:33 AM »
anyone done this ? if so what year cam ?
cb550k3 cafe
Re: 650 cam swap for cb550k3
« Reply #1 on: August 12, 2010, 11:11:17 AM »
All the same but you cant use a tacho as the gear is different
Offline ffjmoore
« Reply #2 on: August 12, 2010, 03:56:05 PM »
As long as its a SOHC 650 it will fit. I hear it makes a pretty good difference. i haven't put mine in yet though.
Offline lordwhimsey
« Reply #3 on: August 12, 2010, 07:33:31 PM »
I heard some rumour that there was a slightly gentler cam profile used on a late model, German market 650, but other than that I think they're all the same.
I've put one in my motor (along with a 592 big bore kit!) but I haven't started it up yet! I'll let you know when I do but you'll have probably got your own by then!
« Reply #4 on: August 13, 2010, 11:25:19 AM »
where did you acquire the cam ?
cb550k3 cafe
Offline ffjmoore
« Reply #5 on: August 13, 2010, 06:43:11 PM »
got mine off ebay
Offline lordwhimsey
« Reply #6 on: August 13, 2010, 07:35:25 PM »
Me too; eBay,
Offline pae
    • Phil's CB650 pages
« Reply #7 on: August 13, 2010, 10:48:52 PM »
Seems to be OK to do this.
In a thread from the 650 forum it states "Be aware that two versions of the camshaft exist, you probably like to have the one with 36mm lobes (63hp) instead of the 33mm (50hp) lobes of some european models."
