Author Topic: Points advance unit  (Read 9354 times)
Offline Matt_Harrington
Points advance unit
« on: November 10, 2023, 09:19:58 AM »
Should one be able to dismantle the advance/retard unit? My spare unit is really stiff and the cam section seems to be reluctant to withdraw from the plate.
Re: Points advance unit
« Reply #1 on: November 10, 2023, 10:27:02 AM »
Pretty sure they come apart when the springs are off much like the Lucas car type.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #2 on: November 10, 2023, 01:01:56 PM »
Yes, they do come apart easily, starting with the springs, but mark the position of the cam first, it can fit 180 degrees wrong on reassembly.
« Last Edit: November 10, 2023, 02:33:08 PM by ka-ja »
nice bike,nothing in the bank
« Reply #3 on: November 10, 2023, 01:51:20 PM »
Thanks. It's going to need persuading!!
« Reply #4 on: November 10, 2023, 02:29:27 PM »
Might need soaking overnight in Evaporust or similar.
« Reply #5 on: November 10, 2023, 03:33:12 PM »
Now apart! It required some effort and now needs a serious clean....
« Reply #6 on: November 10, 2023, 04:56:11 PM »
You could copy what I did with mine Matt, paint in the markings so they stand out when your timing the engine. I did the T marks in red and the F marks in white so they'd really shine under a strobe for instance.
Online Laverda Dave
« Reply #7 on: November 10, 2023, 09:05:20 PM »
Excellent idea Ken, I'll be doing that as trying to see timing marks in daylight with old eyes and wearing glasses is a pain.
Offline Craizeehair
« Reply #8 on: November 11, 2023, 08:57:08 AM »
That’s a good idea, works very well. What paint did you use for that?
« Reply #9 on: November 11, 2023, 09:51:27 AM »
Ken, I did see that a while ago when you posted it. Excellent idea and I'll do something similar, depending on which Humbrol paints are to hand....
« Reply #10 on: November 11, 2023, 12:55:19 PM »
I would avoid just siliver.
« Reply #11 on: November 11, 2023, 02:18:18 PM »
I always use the small pots of Humbrol modelling paint, they last, have a great range of colours and aren't all that expensive. I do the writing on the handlebar switches as well. Also done the seat lock arrow and the black on the rotor cover badges. It lasts and is quite resistant to heat and UV.
« Reply #12 on: November 11, 2023, 03:24:01 PM »
You must have a very small brush Ken or do you use one of those blunt syringes?
Offline Craizeehair
« Reply #13 on: November 11, 2023, 03:27:11 PM »
[/quote]
Cheers, I will get some ordered
« Reply #14 on: November 11, 2023, 04:21:40 PM »
With engraving like that on the switchgear and the advance/retard unit for example I just drop enough paint into the engraving to completely fill it plus a little extra as it shrinks as it dries. I wait a day or so and then either scrape the excess off with my fingernail or a cloth soaked in thinners, thinners is easier BUT if the paint underneath is soft it will take that off a well, ceramic coating is unaffected by thinners, powder coated also resists it but try not to press on hard, just lightly brush the top of the excess is best in my experience. If it's soft paint, like rattle can etc then the fingernail is generally best, just be careful. The problem with the thinners is that it can and does wick down and remove paint inside the engraving as well, which is what happened on my 500 rotor cover on the Made in Japan writing.
Sometimes it's trial and error, find what works best for you. If you don't like having long fingernails for instance ask the wife if she has some spare acrylic nails, they may work.
