Author Topic: Winter work  (Read 3918 times)
Winter work
« on: November 15, 2023, 08:52:08 PM »
As it gets cold,
Salt on the road, time for some
Maintenance and upgrading
The 500 has reached 80,000 miles, so needs new primary chain and a look over
The other is just an upgrading the lighting
The 200 is running well, so available for pottering about
Re: Winter work
« Reply #1 on: November 15, 2023, 09:16:31 PM »
Good time of year for major work John. (80,000mls) impressive.
« Last Edit: November 15, 2023, 09:18:08 PM by Johnny4428 »
Re: Winter work
« Reply #2 on: November 15, 2023, 09:56:16 PM »
Jesus John, what's been rubbing the wiring harness away near the coils. You're lucky that didn't catch fire.
I tend to route mine under the frame member just to avoid that rubbing.
Little tip, never leave the keys in the seat lock, you walk past, catch them with your leg and either break the key or bend it so badly it nearly breaks, plus you hurt your leg in the process.
Is that a DS front mudguard? wrong lower brace if it is.
Re: Winter work
« Reply #3 on: November 15, 2023, 10:02:44 PM »
The front mudguard is original
Same as when I got it in 76,
Not noticed the wiring rubbing
Fitting a relay for 60/55 H4 bulbs
Re: Winter work
« Reply #4 on: November 15, 2023, 10:08:18 PM »
Can't be original John as the lower brace on the original has a loop welded to it for the speedo cable to go through
As in.
https://www.cmsnl.com/honda-cb500k1-four-england_model14660/stay-b-frfender_61112323000/
Re: Winter work
« Reply #5 on: November 15, 2023, 10:17:41 PM »
She'll be good for another 80k John 😁😁😁. I'll give you a race next time we meet up 😂😂😂
Re: Winter work
« Reply #6 on: November 16, 2023, 09:12:45 AM »
As in.
If you look closely, it has
When I fitted the second disc
I closed the link slightly to prevent the cable rubbing on the disc
Re: Winter work
« Reply #7 on: November 16, 2023, 09:13:31 AM »
She'll be good for another 80k John . I'll give you a race next time we meet up
Looking forward to it, not to fast though
