Author Topic: Can't fit rear brake in drum after fitting news brake shoes  (Read 12675 times)
Offline alexdecker
« on: November 19, 2023, 03:57:39 PM »
Hey all
Just installed new brake shoes from CMS bought specifically for my model. But after installing them, I can't make them fit into the actual drum. The brakes are fully retracted, but they just won't fit. Am I missing something here? Usually it goes in really easy and is actually slightly loose.
These are the brake shoes I bought: https://www.cmsnl.com/products/shoesetbrake-non-oe-kevlar_06430390405p/
And then I bought a new brake cam as the old one broke: https://www.cmsnl.com/products/camrear-brake_43141374000/
- Alex
« Last Edit: November 19, 2023, 04:19:06 PM by alexdecker »
Re: Can't fit rear brake in drum after fitting news brake shoes
« Reply #1 on: November 19, 2023, 07:47:02 PM »
Hi Alex my new shoes I just fitted were a tight fit in the actuator recess, make sure they are seated properly, I would even take a file to the ends to make fit easier. And obviously make sure you have the right shoes.
Offline alexdecker
« Reply #2 on: November 19, 2023, 07:50:18 PM »
Hey, thank for the input! Can you elaborate what the actuator recess is?
« Reply #3 on: November 19, 2023, 07:54:18 PM »
The flat spots on the cam that the flat end of the shoe fits into
Offline alexdecker
« Reply #4 on: November 21, 2023, 07:24:05 AM »
So found out these are Vesrah brake shoes. And they fit perfectly in the actuator recess. So I guess they just aren't a fit in general, or that CMS sent me the wrong ones…
« Reply #5 on: November 21, 2023, 09:31:13 AM »
I'd check the part number of those supplied against the manual.
Offline alexdecker
« Reply #6 on: November 21, 2023, 04:09:47 PM »
Here is the part number of the Vesrah brake shoes: VB128S
And here is a picture where I have overlaid the new brake shoe on the old one. You can clearly see that the Vesrah shoe is quite a bit longer. No wonder it didn't fit into the drum.
« Reply #7 on: November 21, 2023, 04:20:17 PM »
You bought 750 ones which are bigger than 500/550 the middle part number should be 323 not 300
Offline alexdecker
« Reply #8 on: November 22, 2023, 08:03:41 AM »
Really? I know this might be misleading, but even on the packaging it says it should fit my bike?
« Reply #9 on: November 22, 2023, 08:19:06 AM »
Just a thought Alex, is your rear wheel hub original or correct for your bike?
« Reply #10 on: November 22, 2023, 03:01:07 PM »
The cms link you posted says they are 750 by the part number, when fitted use a tape measure to measure the diameter of the shoes, there is also a max dia cast inside the drum.
Also has it been relined and machined too small?
« Reply #11 on: November 22, 2023, 04:56:45 PM »
I'm wondering IF the rear drum has been replaced by a previous owner as the 500/550 drums are renowned for cracking, maybe something like a CB500T was used instead.
Any pics of the inside of the drum and the drum in general Alex so we can see if it looks correct.
« Reply #12 on: November 22, 2023, 06:00:40 PM »
Would the inside diameter of a 500 brake hub be handy - it's just slightly under 18.0 cm between the inside edges of the liner measured with an expanding ruler. That probably 17.98 -17.99 cms.
Amended I can't read my stupid tape measure.
« Last Edit: November 22, 2023, 09:11:11 PM by McCabe-Thiele (Ted) »
« Reply #13 on: November 22, 2023, 06:34:40 PM »
Stamped on the inside of the hub Ted
« Reply #14 on: November 22, 2023, 06:49:01 PM »
If that's the case Ken then Alex should easily know if he has a 500 hub.
Only markings in my hub are E-7 & opposite B 1 3
My error it 18.0 cms less a tad not 8!
« Last Edit: November 22, 2023, 09:09:10 PM by McCabe-Thiele (Ted) »
