Author Topic: Timing problems on the 450 Bomber  (Read 72298 times)
Offline mo goldie
Re: Timing problems on the 450 Bomber
« Reply #75 on: December 04, 2023, 12:50:51 PM »
Well now you can have some good news Roy..... I have spark just looked at all the wiring that they say and then tried something and turned over rhe rotor and heard something looked at both spark plugs and got spark .... well nearly fell off my stool lol. Anyway this arvo I am going to take out all the wiring connectors and replace them with the much more neat and works better block connectors like they been using on bikes for years.
Oh then will have to look at the timing rotor.... always something as they say ...but will get there as got time it's winter and dam cold ..so all bikes tucked away.... 😆
Currant BIKES:
1980 Triumph Bonneville 750 T140/D Special Black & Gold
1962 BSA 650 Rocket Gold Star ( silver )
1977 Norton Commando 850 MK3  Interstate ( silver )
1977 Kawasaki KH400 Triple ( Green )
1999 Harley Davidson 1200S sportster Sport ( silver )
1975 Honda Monkey st70 Dax ( Blue )
1967 Honda CB450 KO Black Bomber
Offline mo goldie
« Reply #76 on: December 04, 2023, 09:39:40 PM »
are well now the good news I have it running .... Yahoooooooooooooooooooooooooooooo lol
yp all running the carbs need setting as I did take them all apart and ultrasonic them and the Timing will need to be set too, it is near Roy but like you said on yours it go`s all the way to the end of travel up against the Exhaust cam washer.
so Cam plate is on full Addvance but it sounds good so with some fettling should be all ok,
Did Not hear back from Ashley about the Rotor`s if they are different or Not but it would Not surprise me if they are,
so I have marked the rotor up using a Dial Gauge for top dead centre so if I measure the gap from LF mark and TDC and the mark I have done where TDC is I should be able to to a strobe light on it to get that right do you think ?
Currant BIKES:
« Reply #77 on: December 04, 2023, 09:52:37 PM »
Aye, good stuff there mo.
Yes to timing, as long as you can get a confident degree position against crankcase reference, then strobe it on that to assess.
Offline mo goldie
« Reply #78 on: December 04, 2023, 10:39:23 PM »
Yes Thanks for all your help as its been a bit of a drag at times but we there ha ...well nearly  ;D
got a bit of a leak on the right carb soon fix that but getting them both dialed in and and then I hope will be all good,
is there any way to check if the Rectifier is working as need to check if charging is ok ?
cheers Mo
Currant BIKES:
« Reply #79 on: December 04, 2023, 10:58:12 PM »
Check battery voltage under all conditions, usualy numbers in Honda manual
Offline mo goldie
« Reply #80 on: December 04, 2023, 11:19:02 PM »
Well Bryan
I just fitted one of the Digital ones so wanted to check that it is doing its job right as that is one of the conditions of the warrantee for the E/I .
so first put a meter across the batt see what's going in .... as My battery went a bit flat after using the E/starter for all them times ...so on charge Now.
also still got to sort out a rear light lens as the one I got all cracked too.
Currant BIKES:
« Reply #81 on: December 04, 2023, 11:44:04 PM »
You must remember the 450 charging system is one of Hondas most agricultural ones where extra charging coils are switched in when lights turned on, if the electronic ignition needs a steady precise voltage it should not be on that bike
Offline mo goldie
« Reply #82 on: December 05, 2023, 12:32:03 AM »
Well that's the one they recommend if you don't use it you wont have a warrantee.
   https://www.youtube.com/watch?v=CjTnFcrb3Dg
Currant BIKES:
« Reply #83 on: December 05, 2023, 05:35:25 AM »
You will need to connect your multimeter in series between the battery and the live lead on the 20amp fused connection on your Fluke. Run the engine, but don't use the electric start as it will blow the multimeter fuse, then take a reading and ensure it's over 12 volts. You can't just test these on voltage across battery live and neutral as an AGM battery has more static voltage than the alternator can produce so it doesn't tell you anything. Try it lights on and lights off. If that doesn't make sense to you have a look at the end of my Bomber build thread for a better explanation.
« Reply #84 on: December 05, 2023, 02:21:14 PM »
What was the wiring mistake that caused the lack of spark.
Offline mo goldie
« Reply #85 on: December 05, 2023, 06:35:25 PM »
Hi
Well Roy first my fluke don`t have 20amp its got a 10 amp any good ?
Yes also right about putting a meter across just the battery as it did not move well went down.
the wiring fault if you look back was that the white/Black needed the + 12volt as I thought it was an earth, till as you pointed out that Honda done some strange things on wire colors lol.
if i need to get another alternator are they hard to get or is there someone who rewinds them as might need one  ?
just asking asking as the one on there don't look that good to start with as the windings look to be flapping around well some of them do anyway,
Currant BIKES:
« Reply #86 on: December 05, 2023, 09:09:24 PM »
Windings are fairly robust, charging problem are usually bad wire or wron connections
« Reply #87 on: December 05, 2023, 09:46:16 PM »
Bomber ones often fooked Bryan .. particularly when damaged when the starter clutch fails (which must have happened on Mo's bike) .. plus they are cloth wound not epoxy coated, The later 5-speed fits OK and is epoxy dipped like later 1970's Hondas.
« Reply #88 on: December 05, 2023, 11:13:28 PM »
Thanks Ash, only ever did the 500twin, in that case measure the ac output of the wingings when running
Offline mo goldie
« Reply #89 on: December 05, 2023, 11:46:09 PM »
I just wish I could get one ha LOL.
Hi Ashley
did you get tro look at the rotor`s ?
i got my timing near as you can get it right so rotro must be ok ...........running a bit like a pig tho....... carbs need setting up
I think.
Currant BIKES:
