Author Topic: I think I've done something wrong!  (Read 24372 times)
Re: I think I've done something wrong!
« Reply #45 on: October 22, 2024, 10:49:46 PM »
I'm the same, I don't like doing valve clearances so do my best to get each one spot on first time.
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #46 on: July 04, 2025, 11:01:23 AM »
Well, since last time ....
Everything went back together, but an electrical gremlin prevented me from trying to start the engine. So after spending Xmas at home in France, I continued my RTW trip to Belfast(s).
belfast2belfastbybike.com) for anyone interested
I have now done NZ and Oz, then got held up by the Pakistan/India dispute, spent 2 weeks on little hired bikes with my sons in northern Pakistan, and now, because of the Israeli action in the Middle East, my 750 is being stored in The Bikers Cafe, Dubai
https://www.facebook.com/search/top/?q=bikers%20cafe%20dubai If you're in Dubai, pay a visit; the food is great and the strawberry milkshake wonderful!  :)
However, every cloud ....  This delay allowed me to return to Rusty the 400F2.
Without too much effort the engine started, but it was lumpy.  The oil pressure light didn't go out either, and then I realised I hadn't put any oil in after the last episode!  :-[. The carbs were overflowing. and the throttle grip was sticking.
So I removed the carbs, cleaned and blew through the jets, did a bench synch leaving the slides at 3mm using the idle screw, set float heights at 21+/- (range 20,5-21,5) and replaced them - what a job replacing them is! I removed the powder coating from the right handlebar and the grip started moving much more freely.
Rusty fired up with the first prod of the starter  :D, responded well to the throttle but wouldn't drop below 4000. She started several times with the same result.
https://youtube.com/shorts/jydaCl9nJXU?feature=share
Checking the plugs, 1, 2 & 4 were clean, but No 3 was black. I unscrewed the idle screw fully, and reset the air screw at 2 turns out - they were at 4 turns out!
The bike wouldn't start! There was a good spark, and fuel seemed to be getting through. At this point I noticed that the starter spun much more freely when the kill switch was off, and there was an unsettling noise from the engine when it was on. I was about to start from scratch with checking the valves and timing when I noticed some oil on the floor  :o There was a hole in the clutch cover; the bolt retaining the secondary drive gear had come loose and punched it's way through the crankcase!
Sorry for the biblical length of the post, but a few clear questions:
  • Apart from the hole in the crankcase, what damage might the loose bolt have cause?
  • I plan to try to fix the hole with JB Weld Extreme Heat; any thoughts?
[li] What can I now do the get it running again (once the hole is repaired)? Go through the usual suspect list of valves, timing and carbs  :( ? Or is there something I have forgotten?
[/li][/list]
Offline SeanFD
« Reply #47 on: July 09, 2025, 11:30:56 PM »
Nearly a week later and the engine is running again.
The problem? Me!! ::)
I used JB Weld Extreme Heat to repair the case cover; it doesn't look pretty, but seems to be working. First replacement, the kick starter wasn't positioned correctly and just spun freely without moving anything. Second replacement, the clutch lifter mechanism came out of position, so the clutch lever wouldn't move. Third replacement, all went well, thankfully.
I'm not sure I followed the procedure correctly when synching the carbs, but when I started up, the engine ran, still fast and with a poor response to the throttle. Plug no 4 this time was black.
Adjusting No 4 air screw would bring down the idle, but there was little response to the other screws. Checked the plugs and switched 1 & 4. All plugs were good and the switch made no difference.
So I bit the bullet and took the carbs off again. I hadn't followed the procedure properly! the slides were at 3mm with the idle screw fully out; no wonder it was revving high.
Set things properly (?) this time: all slides bottomed out; No 4 set at 3mm using the idle screw; the other 3 then set to 3mm using the individual adjustment screws. Yes?
Then when re-assembling the carbs, the float bowl o-rings (Why did I open the float bowl when all I was doing was a bench synch? Good question!) had expanded so much they wouldn't fit back in. So I've ordered a new o-ring kit from Nurse Julie - thank you.
Meanwhile, being impatient now, I decided to try a temporary – if it works it'll stay there till it stops working  :)) – fix. I cut the o-rings, removed about 2-3mm – tailored for each bowl – and stuck it back together with superglue. First test rigged on the bench suggests it's holding.
Well it's still holding, carbs are back on - what a bugger that airbag is – and tomorrow will tell.
