Author Topic: 750 Rotor Puller  (Read 11126 times)
750 Rotor Puller
« on: January 20, 2024, 04:48:40 PM »
Can anyone please advise off the rotor puller size/thread please. Need it off to replace the starter clutch as it slips occasionally. I have a R/H M20 x 1.5 bolt that I'm sure I've used this before but it won't start to screw in
Re: 750 Rotor Puller
« Reply #1 on: January 20, 2024, 06:25:07 PM »
I use a Fiat Ducato Van wheel bolt. Dirt cheap on ebay
M14x1.5
https://www.ebay.co.uk/itm/134149268605
« Last Edit: January 20, 2024, 06:30:38 PM by AshimotoK0 »
« Reply #2 on: January 20, 2024, 06:49:33 PM »
Defo not m14 Ash as 18mm bolt is loose in the hole. Think its the end of M20 bolt thats nackered - tried filing bolt end but no luck. Don't want to force in case I knacker the rotor thread
« Reply #3 on: January 20, 2024, 07:08:11 PM »
How urgent is this Phil?
I can bring over my genuine Honda rotor puller when I pop over if that helps, missus is still pretty poorly so not sure when that will be but maybe next week if that's ok.
« Reply #4 on: January 20, 2024, 07:44:11 PM »
Thanks Ken but probably difficult to juggle a time thats convenient for us both as I am at Christie's in Manchester for radiotherapy (different times every day Monday to Friday) and Hyperberic Oxygen treatment (alternative supporting therapy) each day in Chorley in the other part of the day - so most of each day taken up battling this b*****d tumor!
Wait until your wifes better - parts arn't going anywhere so you can pick them up after she's better
I'll order a puller off eBay so probably won't work on it until next weekend
« Last Edit: January 20, 2024, 08:11:36 PM by philward »
« Reply #5 on: January 20, 2024, 07:49:18 PM »
Sorry Phil .. the M14 must be for the CB250/350
According to what I read on internet it's M20x1.5
« Last Edit: January 20, 2024, 07:52:24 PM by AshimotoK0 »
« Reply #6 on: January 20, 2024, 08:15:06 PM »
Thanks Ash, I'll see if I can clean up the threads and if it doesn't work 'I'll order one off eBay
« Reply #7 on: January 21, 2024, 01:14:11 PM »
Can't remember if it's 750 but I did once use a rear axle to remove one. Fitted perfectly but no idea what the thread size was. I was just trying everything I had to hand that day.
« Reply #8 on: January 21, 2024, 01:17:49 PM »
Tried that but it's too small Roy
Sent from my moto g(50) using Tapatalk
« Reply #9 on: January 21, 2024, 04:46:50 PM »
Read somewhere an that oil filter bolt fits ... not so sure myself
Offline Pauarc
« Reply #10 on: January 25, 2024, 08:31:57 AM »
Honda tool no 07933-000000  20x1.5 bolt
Honda 90ss, Cb250k1 supper sport,
Cb400 four, CB750k7, Cb550, Cb750f2n,
Cb750k2
