CB350/400
Painting underside of rear fender
Topic: Painting underside of rear fender (Read 3893 times)
Athame57
February 16, 2024, 08:29:06 PM »
My rear fender has a lot of blemishes appearing under it now, so sometime soon I'll be taking it out for a good sprucing up. Is it a bad idea to paint beneath it, how should I best go about the job?
Last Edit: February 17, 2024, 12:07:13 AM by Athame57
1978 CB400F2 named Elen.
ozzybud
SOHC Member
Re: Painting underside of rear
February 16, 2024, 09:47:41 PM »
It was the standard Honda flash Chrome from the factory which is very thin. I would suggest scrubbing with Scotcbrite or steel wool. Then use Por-15 or a similar rust neutralizer. Then rattle can some silver metallic paint over that. It will be easy to keep clean and look attractive.
1976 Z50 PARAKEET YELLOW
1970 CT70 CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVERA BLUE
1973 CB350F FLAKE MATADOR RED
1974 CB350F GLORY BLUE BLACK
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Bradders
SOHC Expert
February 16, 2024, 11:33:33 PM »
I have just done the underside of both of my mudguards, I derusted as much as possible with I think it was Kurust and painted with silver Hammerite. I’m pleased with the look but I guess only time will tell how it lasts. I never use my bike if the roads are wet or salty though.
davidcumbria
Such great knowledge and support on here 👍
SOHC Expert
Re: Painting underside of rear fender
February 17, 2024, 06:38:43 AM »
After rust treating and paint spraying I think a protective coating of xcp rust prevention spray should keep it good. It is much more robust than acf50 ( does way better on tests ) and forms a hard protective skin.
500/4 in 79. No bikes for 30 years. 750/4 in 2013, 550/4 in 2023. Also own R1100GS, RD350LC YPVS , Yamaha fazer 600, Yamaha XT250, BmwR80 , HondaVT1300, Royal Alloy GT125.
DomP
February 17, 2024, 08:36:21 AM »
Another option after treating the rust with something like deox gel is bilt hamber dynax ub, it's a dark brown/black coloured self healing underbody wax.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Laverda Dave
Health is wealth
February 17, 2024, 10:50:43 AM »
This is an interesting thread. I'm collecting my chrome from Ashford Plating on Monday and will paint the underside of the front and rear mudguards, the chainguard (although flung off chain lube will help keep that rust free) and the underside of the points cover to stop the potential arcing from the points.
I remember froma previous thread posted by Ken (Oddjob) a while ago where he mentioned about rust forming in the rolled edges in the mudguards.
McCabe-Thiele (Ted)
February 17, 2024, 12:03:06 PM »
On my 500 I used the Zinc Galvanising paint followed by a silver engine paint when base coat completely dry.
Link to my full restoration
CB350/400
