Author Topic: Brake calliper silicone grease  (Read 6678 times)
Offline Cb750r
Re: Brake calliper silicone grease
« Reply #15 on: February 20, 2024, 06:10:31 AM »
You folks will have easy access to Millers Red rubber grease, which states clear on it: For piston seals in brake circuits
I have a small tub of SRAM DOT grease as I’m also an avid cyclist and it’s used often when doing calliper and piston rebuilds. I use a super light film on the seals and pistons when sliding them in the bores.
