CB350/400
Engine paint
Topic: Engine paint (Read 13976 times)
exvalvesetdabbler
Engine paint
September 01, 2010, 12:15:15 AM »
I don't know what people are using these days, when I painted my rocker cover,front sprocket cover and alternator housing I used Sperex VHT engine enamel. It was imported by a local motor factors form the states. I think it may have later been branded as Holts.
The trick is to get it cured before you get any oil or fuel on it.
You need to wait until mum/wife (delete at appropriate) is out, open all of the the windows and shove it in the oven for about an hour at 80-100 deg. Mine was done 20 years ago and it has lasted despite having a leaking carb gasket for the past 2 years. No primer - just a rub down with 400 wet'n'dry and washing up liquid.
Theres no need to lacquer over this stuff and in most cases lacquer will just yellow and spoil it.
Just to verify that I don't throw anything away ....
Regards
Dave.
Last Edit: September 01, 2010, 12:22:25 AM by exvalvesetdabbler
PatM
SOHC Member
2001 R1, Triumph 1200 and the little 400/4!
Re: Engine paint
September 01, 2010, 08:39:02 AM »
Dave
Your comments make good reading- especially the bit about the over- although I doubt the engine would have fitted, but next time its out- Ill try.
When my carbs leaked shortly after re-commissioning mine- there was a pool of silver on the floor- depite the fact the engine had been run a few times and allowed to cool..
whatever next? carbs in the diswasher- a sort oof DIY ultra-sonic clean maybe..
steven400/4
SOHC Expert
Re: Engine paint
September 01, 2010, 08:35:01 PM »
in the usa they use sims silver wheel paint then heat it up looks real cool
cb400f2 x7
honda ss 50
gsx 1400
K2-K6
Re: Engine paint
September 01, 2010, 09:14:39 PM »
Hmmmm nice old spray can there, somebody somewhere is probably restoring those!
Think the design spec of engine oil is 90 C so unlikely to get some of the outside cases to cure by running the motor I'd guess. Sounds like a pretty effective method of the oven if it's lasted for that long, thanks for the tip Dave. Spose you'd get more of the 400-4 bits into a domestic oven than bigger 750 bits.
On that angle we used to use something called "Vi-cote" that appeared to be like a spray on clear vinyl (that's the best way I can describe it) it was particularly good on ali casings that where mildly polished or brushed surface and seemed to give an impervious-to-weather coating, don't know if that's evolved into anything though.
rigwit
Re: Engine paint
September 02, 2010, 12:41:15 PM »
I always used sperex vht on the pipes i made for bikes, downpipes and cans, one thing i did learn well on, was that like you said -you have to cure it b4 it will perform as it states, (first few pipes i made i used the exhust heat to cure and it crinckled) but once i realised how to do it ive never had it leach out by oil petrol etc, flake, off allow rust behind it. ive done barrels as well with it and never let me down was top notch stuff
Spitfire
Re: Engine paint
September 02, 2010, 01:44:06 PM »
Most of my CB750 engine went in the oven, just don't overcook it as it goes yellow !
Here's the paint, left to dry overnight and then baked, sure smells bad.
Den
steven400/4
SOHC Expert
Re: Engine paint
September 02, 2010, 07:37:32 PM »
so how long did you leave in the oven
cb400f2 x7
honda ss 50
gsx 1400
Spitfire
Re: Engine paint
September 02, 2010, 08:11:31 PM »
Can't remember now but I followed the instructions on the can (US Automotive VHT), apart from setting the oven for centigrade instead of Fahrenheit, hence how I know it goes yellow !
Den
steven400/4
SOHC Expert
Re: Engine paint
September 02, 2010, 09:09:59 PM »
ok mate no problem
cb400f2 x7
honda ss 50
gsx 1400
K2-K6
Re: Engine paint
September 02, 2010, 09:19:29 PM »
That picture of the head in oven cheered me up Den, so they will fit then as I've got two to do eventually.
Have visions of you oiking the sunday roast out of the way to get the bike painted!
exvalvesetdabbler
Re: Engine paint
Reply #10 on:
September 02, 2010, 11:04:07 PM »
That oven looks a bit clean/new. Even I'm not brave enough to risk getting caught putting bike bits in a new oven.
Spitfire
Re: Engine paint
Reply #11 on:
September 03, 2010, 08:20:31 AM »
Well the "Boss" could not complain as I'd just spent an arm and a leg getting her dream kitchen fitted, plus to be fair she does support all my various hobbies.
Den
florence
Re: Engine paint
Reply #12 on:
September 03, 2010, 08:50:41 AM »
Why would one want to put enamel on the engine? Someone tried put some on one of my old engines before I owned it; it just cracked and flaked and looked awful and ruined the case. I don't know how to remove what's left. Bare aluminium is much nicer, mine has a lovely polish mark on the clutch casing where my boot has rubbed it over the years. The rest has a lovely matt oxide finish that has taken me years to culture.
K2-K6
Re: Engine paint
Reply #13 on:
September 03, 2010, 10:05:49 PM »
As far as I'm aware the standard finish for all pre F2 750 SOHC was painted/enamelled cases, barrels, head, oil fiter castings with all outer castings, rocker, alternator, gear, clutch, sprocket being light polish/brushed and laquered ali. stops that furry look you get on raw clean ali castings.
exvalvesetdabbler
Re: Engine paint
Reply #14 on:
September 03, 2010, 11:00:46 PM »
I don't ever remember the sump, barrels and head being painted on 400/4's.
When I stripped my rocker cover many years ago the original paint was more like a modern day metallic having a silver base coat topped off with lacquer.
I have a NOS head and rocker cover, the head is bare ali' and the rocker cover is painted. I've never found an exact match for it in off the shelf spray cans it to date. The VHT SP127 engine enamel is the closest match that keeps its looks the longest.
Regards
Dave
CB350/400
Engine paint
