Author Topic: A Tale Of Two Sprockets .............  (Read 7877 times)
Offline colin400four
« on: September 03, 2010, 07:25:33 PM »
Hi to all,
as you all know to try and find a new rear sprocket with an original gaurd fitted for the 400/4 is pretty difficult, so I came about this " used Sprocket " which looked like it had plenty of life left in it, but still classed as usedand tatty, SO, out came the paint and I "tarted " up the sprocket and guard.
Not bad I thought, but still a niggling thought that no matter what I did it was always going to be a used Sprocket.......... see first set of pics.
So, plan 2, get a new after market spocket, an old guard, restore the old guard and then rivet the gaurd to the new sprocket, Looks o.k and now with a new sprocket  :D see second set of pics
COLIN.
Re: A Tale Of Two Sprockets .............
« Reply #1 on: September 03, 2010, 07:27:45 PM »
and these
Offline UK Pete
« Reply #2 on: September 03, 2010, 08:21:54 PM »
Superb bit of work there welldone
pete
Offline PatM
« Reply #3 on: September 03, 2010, 09:21:13 PM »
Yep, all looks Brand New!
Offline exvalvesetdabbler
« Reply #4 on: September 03, 2010, 11:02:06 PM »
Looks good.
How did you rivet it up without chipping the paint?
« Reply #5 on: September 04, 2010, 08:37:34 AM »
Thans for the kind remarks,
With regards to the rivets, I had to use 5x16 mm rivets, big buggers, which on a test piece broke my crap cheepo pop rivet gun, didn't help I guess as I was asking the gun to "pop" a size it was not made for , so I invested in a big bad lazy tongue pop riveter and this did the job with no problems.
With regards to chipping the paint, the way that you insert / pop the rivet, all the force seems to be taken on the actual rivet face , and the way you use a lazy tongue riveter as apposed to the little hand held riveters gave a much easier way to pop the rivet, (didn't need as much force ) so chipping was not a problem.
COLIN.
