Author Topic: First start after rebuild  (Read 23072 times)
Re: First start after rebuild
« Reply #30 on: March 10, 2024, 07:56:04 PM »
Well done Dom. As Bryan says, get it on the road first and get some miles on her, don't leave her ticking over for very long at this stage to play with the carbs, it needs to go through lots of heat cycles with cool air getting around the fins to help the rings cut in. I bet you are well pleased and so you should be.
Offline DomP
« Reply #31 on: March 10, 2024, 09:04:37 PM »
I would if it was ready for the road but I need to sort the seat, indicators, brake light etc as its not standard anymore so I'm going to have to get inventive.  Very much a work in progress
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #32 on: March 10, 2024, 09:12:18 PM »
As said needs to be on the road to run in, short engine runs not good
« Reply #33 on: March 10, 2024, 09:14:17 PM »
No problem,
Get everything finalised,
Then run the motor
« Reply #34 on: March 10, 2024, 09:18:57 PM »
Great news Dom always a relief to know she’s a runner and you have an indication of oil pressure.👍
Offline davidcumbria
« Reply #35 on: March 10, 2024, 10:15:56 PM »
Good news and some riding to look forward to 👏👍
Offline Jan B
  • Everything you can leave behind is a gain
« Reply #36 on: March 11, 2024, 10:02:06 PM »
Exiting news. I'll bet you are chuffed!
CB500K1
CB750K2 [project]
BMW F800GS
Offline DomP
« Reply #37 on: March 11, 2024, 10:53:45 PM »
Very Happy Jan, I do realise why Ken says do engine last though!
1975 XS650B
« Reply #38 on: March 11, 2024, 11:13:56 PM »
Ken is spot on with that, I can't really even mount my exhausts as the wheel hubs are still at CWC.
I feel the bike is too unstable to fit the exhaust & start the engine with no wheels fitted.
« Reply #39 on: March 12, 2024, 08:17:17 AM »
Well done 👍. Always a great feeling (and a huge relief) when they start with no problems.
Offline DomP
« Reply #40 on: March 12, 2024, 04:01:19 PM »
I do wonder though if I should warm it up to get any condensation out?
1975 XS650B
« Reply #41 on: March 12, 2024, 04:28:29 PM »
No,
Unless it gets to full working temperature, it's likely the moisture will turn acidic,
Ideally ride it for the minimum of 10miles,
Always get it hot,
« Reply #42 on: March 12, 2024, 05:46:45 PM »
Getting it warm will cause more condensation but a lot more importantly, unless you have a lot of cold air going around those fins, there is a very high risk the engine will seize.
Offline DomP
« Reply #43 on: March 12, 2024, 06:59:44 PM »
My concern is that its not yet road worthy so what should I do now having got it running
1975 XS650B
« Reply #44 on: March 12, 2024, 07:31:44 PM »
Absolutely nothing. Wait until it's road worthy.
« Last Edit: March 12, 2024, 07:35:03 PM by Nurse Julie »
