Author Topic: Fixing fins  (Read 3699 times)
Offline Athame57
Fixing fins
« on: March 11, 2024, 03:02:28 PM »
I'm considering a purchase of a cylinder block just now on two provisos, that it is still available next month and it can be repaired. As you can see there is some fin damage, I gather this can be repaired but would one need to also bring the bits that broke off and would it cost the earth to have the job done?
What you told me rules out the idea.
« Last Edit: March 11, 2024, 03:48:50 PM by Athame57 »
1978 CB400F2 named Elen.
Re: Fixing fins
« Reply #1 on: March 11, 2024, 03:08:06 PM »
That could easily cost up to £150, maybe more. All the fins need chopping out from the top downwards, so you can get to where you need to be, and you would also need a donor barrel to cut some donor parts out to weld in. Why do you need a replacent George.
Offline Athame57
Re: Fixing fins
« Reply #2 on: March 11, 2024, 03:48:19 PM »
Hi Julie, a replacement is on the cards because my present block on inspection has one bore scratched if not all that bad by a broken piston ring, I think that the new piston rings that have gone in will reduce the white smoke at high revs ( it isn't very bad though). I just can't find anywhere to get a rebore in London so I considered plane swapping the block and maybe at some stage put the other on Ebay whatever.
I expect my bike back in a few days at last, I've been getting a bit frustrated maybe that is producing bad ideas lol.
Stop Press: I seem to have discovered a place in reach, ....hope!
« Last Edit: March 11, 2024, 04:02:20 PM by Athame57 »
Re: Fixing fins
« Reply #3 on: March 11, 2024, 04:39:53 PM »
Try a resleeve,,
I am sure it can be done
Re: Fixing fins
« Reply #4 on: March 11, 2024, 05:07:19 PM »
What bike is it? I have 500 and 550 blocks about at various sizes
Offline Athame57
Re: Fixing fins
« Reply #5 on: March 11, 2024, 07:38:04 PM »
It is a 400 Brian, but I've lost interest now.
