Author Topic: Numberplate bracket  (Read 15007 times)
Offline DomP
Numberplate bracket
« on: March 18, 2024, 06:15:37 PM »
I'm trying to settle on a side mount design for my project and remember seeing one that I think Julie has on her bike, I've tried searching for it but failed.  Am I right and if so can anyone direct me to it?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: Numberplate bracket
« Reply #1 on: March 18, 2024, 06:45:44 PM »
I'll post the link in a minute Dom.
I can take a photo of it close up with the number plate attached if you need more info.
http://www.sohc.co.uk/index.php/topic,15889.msg135009.html#msg135009
http://www.sohc.co.uk/index.php/topic,27187.msg251371.html#msg251371
« Last Edit: March 18, 2024, 06:50:12 PM by Nurse Julie »
Offline Athame57
« Reply #2 on: March 18, 2024, 08:24:37 PM »
Hi Dom
Why not test the powers that be with this arrangement sported by the lovely Katey Abdilla on her steed Billie? This is in Tasmania, I hasten to add, you'll be testing different waters.  ;D
1978 CB400F2 named Elen.
Offline DomP
« Reply #3 on: March 18, 2024, 08:30:01 PM »
Thanks Julie, how is it attached, via the axle bolt?
1975 XS650B
Offline DomP
« Reply #4 on: March 18, 2024, 08:32:34 PM »
Hi Dom
Haha! I think that's pushing it a bit
1975 XS650B
Offline DomP
« Reply #5 on: March 20, 2024, 07:55:49 AM »
(Attachment Link)
Actually if you get a moment that would be useful Julie, thanks.
1975 XS650B
« Reply #6 on: March 20, 2024, 08:15:29 AM »
OK, Dom, I'll take some later today.
« Reply #7 on: March 20, 2024, 03:44:06 PM »
Here you are Dom. This has s Graham's Mongrel as it was near the front of the queue, the bracket that Graham designed and made is identical to that which is fitted to Millie.
« Last Edit: March 20, 2024, 03:45:50 PM by Nurse Julie »
« Reply #8 on: March 20, 2024, 05:41:21 PM »
There are a raft of different mounting brackets on e-bay - all sensibly priced some with lamp units.
Offline DomP
« Reply #9 on: March 20, 2024, 10:50:27 PM »
Thanks Julie that's perfect, is the shock end spread to fit the bracket between it and the bush?
1975 XS650B
« Reply #10 on: March 21, 2024, 08:11:23 AM »
These are TEC shocks Dom. They are very slightly wider at the bottom and ordinarily a washer goes there but we just leave the washer out and fit the bracket there instead.
