Author Topic: 67` Bomber running problems  (Read 74110 times)
Offline mo goldie
Re: 67` Bomber running problems
« Reply #30 on: April 14, 2024, 06:19:34 PM »
Hi K2-K6
well it was a steel washer up against the oil seal and held in by the Circlip. I have been on it today and fitted all the new springs Etc... and it all done as far as I can go as just waiting for that rear Tank Rubber if I can make that fit too, as I can`t get one of the ones that it is meant to have as I did Not even know it was meant to have one till I looked in the Manual, so I can put the tank back on and then Try it out ... ( weather depending tho ) good bloke Ashley is going to see if he can get any of the old Carb kits he had a while ago from people who had more than they Might have needed so that will be really good if he can...... so fingers crossed Ha
and I should be able to get to the show Next weekend  ;D
Currant BIKES:
1980 Triumph Bonneville 750 T140/D Special Black & Gold
1962 BSA 650 Rocket Gold Star ( silver )
1977 Norton Commando 850 MK3  Interstate ( silver )
1977 Kawasaki KH400 Triple ( Green )
1999 Harley Davidson 1200S sportster Sport ( silver )
1975 Honda Monkey st70 Dax ( Blue )
1967 Honda CB450 KO Black Bomber
« Reply #31 on: April 15, 2024, 07:38:59 AM »
Good news Mo, hopefully another little problem sorted and good to get it to the show too.
There's often a few bits on most older bike that's needed in sorting out, despite what was claimed from seller. Hopefully you're closer to having how you want it now with the work you've done. It does feel better if you can get reasonably conclusive fixes in place, along with the confidence to take it out more.
Offline mo goldie
« Reply #32 on: April 16, 2024, 06:51:05 PM »
Yes thanks it is good news after all the problems I have Had..... but thanks to all you Guy`s on the Honda Forum and Ashley who has helped me out big time and hope he can help out on the last thing I require to finish it right off is the Carb kits that he said back in the day to sort out that Dam Flatspot at the 4,000 rev range.... as he said them at the DSS did Not even Know about them even when he sent them the info for them either  :-\ ..... But hope Ash can find some out there for me I will be well chuffed.... I also will put some pictures on here when I do get her out for some shots.
Thanks all
Mo
Currant BIKES:
Offline mo goldie
« Reply #33 on: April 20, 2024, 10:11:57 PM »
Hi Guy`s
Just an update..... well after it rained and I thought I would Not Take the Bomber to the show rain all cleared up by 10;00 am so my mates on there CL305 and CB77 super hawk got to the show...... had a Great day None of us won anything tho as the scooter lot seemed to win it all ( yes well what can I say :) )........... but ha ho the main thing I have to report is that the Bomber went like a dream, as the other day when I took it out it kept missing and that 4,000 rev`s problem was there............ well I messed about with the Carb`s and the plugs I had set at 30 as book say between 28 - 32 so had them at 30.....so changed them to 28, well what can I say....... I am leaving everything as it is as I say it went like a dream No missing and the 4,000rev`s  it did not even have a hiccup anywhere Now ..... so as I say if it runs well don`t fiddle ha.
cheers Mo
Currant BIKES:
« Reply #34 on: April 20, 2024, 10:14:15 PM »
That sounds like a result Mo, well done that man 8).
Shame about the scooters hoovering up all the prizes:(
Offline mo goldie
« Reply #35 on: April 20, 2024, 10:23:37 PM »
Thanks Dave
yes that was the best result of the day................. Dam Scooters lol But well chuffed Thanks  ;D
Currant BIKES:
Offline mo goldie
« Reply #36 on: May 01, 2024, 06:48:16 PM »
here we go again  :-X
Well been trying all day to get a better running Bomber...... it misses sometimes and it pop`s on the over run well most of the time it doo, I have this morning taken off the cam covers and re-done the Valve clearance`s also looked again at the ign Timing checked out and re-gaped the plugs also set the mixtures using a colour tune which I got to a Nice Blue colour, the other thing I thought about is if there was a leak in the exhaust somewhere........... I still wonder if it is running rich or lean around that 1/4 throttle opening ?
Weather being kind i`ts the vintage run on sunday....But I keep Trying to sort it dont no what else to try ?  ........... don't know if its still something to do with the Kits that Ashely said about ....... and Main Jet by the way is the standard 125 ...but I have not got any bigger ones to try if it needs to go that way LOL  ;D
« Last Edit: May 01, 2024, 06:54:32 PM by mo goldie »
Currant BIKES:
Offline mo goldie
« Reply #37 on: May 17, 2024, 03:38:36 PM »
Hi Everyone
Well been trying to find a rear drive Sprocket for the Bomber but can`t seem to get one  ::) I have a new front one and a new chain. but do anyone know where to buy one from DSS has none  :'(
Currant BIKES:
« Reply #38 on: May 17, 2024, 05:57:57 PM »
CMS show 38 and 39 toothin stock, what size are you after
« Reply #39 on: May 17, 2024, 06:19:27 PM »
I believe the standard is 35T Bryan
Offline mo goldie
« Reply #40 on: May 17, 2024, 06:26:52 PM »
Hi
yes it is 35 std so would like to get one of them..... I don't know what it will pull like as I got a 17T Front one to go on and std is 15T so will have to see...... just need to get a 35T rear.
Currant BIKES:
« Reply #41 on: May 18, 2024, 08:17:22 AM »
15 to 17 is a big jump, personally i would fit one of the bigger rears from cms to compensate
« Reply #42 on: May 18, 2024, 08:42:36 AM »
I would just go for the sizes used on the original bike on both the front and the  rear. Someone must do an aftermarket 35T that would fit Mo.
« Reply #43 on: May 18, 2024, 09:17:10 AM »
I did some math and 17/39 is damn near same as 15/35 and the cms one would  be here fairly quicly.
The rear sprocket part numbers only fit the various 450 models according to cms so probably not easy to get aftermarket now
Offline mo goldie
« Reply #44 on: May 18, 2024, 03:49:24 PM »
Hi Guys
yes it is a big ask to try the 17T front just wanted to bring the revs down as its doing about 6.000 rev`s at 55 mph so was just going to try that set up...... But ha ho can`t even get a rear sprocket..... I am Not a Rich man ..... and about a £100 + P+P for a sprocket is just Dam robbery....... Like you say Ash they must be someone doing an after market one... BUT I can`t fined one  :'(
 PS, I am Not used to the high Revving Honda :)
« Last Edit: May 18, 2024, 03:53:43 PM by mo goldie »
Currant BIKES:
