Author Topic: 67` Bomber running problems  (Read 72950 times)
Offline mo goldie
Re: 67` Bomber running problems
« Reply #45 on: May 18, 2024, 04:16:48 PM »
can anyone supply the following .....as a bloke has asked if I can supply them he will see what he can come up with if anything ?
so he said if you supply me with the diameter of the centre hole and the p.c.d. with hole diameter and the number of holes and the chain pitch
well I Know it is a 530 pitch chain but Not the other bits  ;D
Currant BIKES:
1980 Triumph Bonneville 750 T140/D Special Black & Gold
1962 BSA 650 Rocket Gold Star ( silver )
1977 Norton Commando 850 MK3  Interstate ( silver )
1977 Kawasaki KH400 Triple ( Green )
1999 Harley Davidson 1200S sportster Sport ( silver )
1975 Honda Monkey st70 Dax ( Blue )
1967 Honda CB450 KO Black Bomber
« Reply #46 on: May 18, 2024, 04:26:03 PM »
Do you not have an old sprocket to give him?
Offline mo goldie
« Reply #47 on: May 18, 2024, 07:13:27 PM »
Hi Bryan
Well I am using the bike so don`t want to take it off the road yet if you know what I mean......... so just wondered if someone has one already got one off that they could do a dimension check ?
Currant BIKES:
« Reply #48 on: May 18, 2024, 08:18:14 PM »
Have you considered that running 17/35 sprockets has dropped your revs for running speed and may be contributing to your running problem? It was designed to cruise at a certain rev range
Offline mo goldie
« Reply #49 on: May 18, 2024, 10:35:34 PM »
well I might have to keep the set up then as a 15T and 35T ......... the running of the bike is fine now ..well near on anyway ..but the revs just seem to be so high :(
oh the other thing is I have been on the DSS and looked at Ashley`s parts list and they did do a 17T sprocket for the Bomber so it must have been able to run with a 17T ha
« Last Edit: May 19, 2024, 12:33:05 AM by mo goldie »
Currant BIKES:
« Reply #50 on: May 19, 2024, 01:05:26 AM »
Honda always list alternate sprockets but they were designed with a ratio and yes, compared to british iron, they do seem to rev high BUT its higher up the rev band they give rated power, the 500 handbook says not to go out of the top of the red too often
« Reply #51 on: May 19, 2024, 11:51:03 AM »
Cursing you today Mo ... 'cos I had to go to the bowels of my stash to find this to measure for you.  ;D ;D ;D
4 mount holes around 9.7 mm Dia. Large centre hole 73.7 mm Dia.
« Last Edit: May 19, 2024, 11:55:26 AM by AshimotoK0 »
Offline mo goldie
« Reply #52 on: May 19, 2024, 07:19:03 PM »
are thanks Ash........ well its Not just the mrs then that I upset LOL
so I have sent that off to the bloke .... I hope he will find a sprocket that will fit with them Dimensions.
so thanks Again Ash to the rescue  ;D or should I say MR Honda  ;D
Currant BIKES:
« Reply #53 on: May 19, 2024, 08:58:58 PM »
Well it went OK 'cos I found a NOS one in there for my own Bomber I wasn't aware I had  and didn't realise they are so rare !
Offline mo goldie
« Reply #54 on: May 19, 2024, 10:27:47 PM »
are goodo then Ash I was some use ha......... pity you did Not Have two ha :(
that would have made it all the more worth while  ;D
Currant BIKES:
Offline mo goldie
« Reply #55 on: May 20, 2024, 08:06:46 PM »
Hi Ash
This is what he sent back so if you Know what he is on about can you have anther look at the sprocket please to give him the more info.
Hi, You have not said what chain pitch you have but I assume it is 530. The 4 mounting bolt holes distance apart (known as the p.c.d.) is taken from the centres of the bolt holes.
I make it 74mm centre hole as there is nothing listed with 73.7mm. The p.c.d. at 110mm with 10mm bolt holes.
Is the sprocket flat on both sides or a recessed ring on the inner face? I think it might be 280 sprocket type but I now need to check to see if this is still available.
Currant BIKES:
« Reply #56 on: May 20, 2024, 08:08:58 PM »
Hi Ash
May be simpler if I donate my used one to you to give him. Just pay postage.
Offline mo goldie
« Reply #57 on: May 20, 2024, 08:15:01 PM »
Well he is just a bloke on Ebay Ash so don`t know how good he is..........as he just asked to supply the dimensions so he could check to see if they is one to match it ..... so if you can just tell me if it is flat on both sides will due I think.
Currant BIKES:
« Reply #58 on: May 20, 2024, 10:13:57 PM »
Part number is 41201283000 so i would say 283 not 280 but that is a pure guess
Offline mo goldie
« Reply #59 on: May 20, 2024, 10:22:34 PM »
You have lost me with that one ?
tried them in DSS and all discontinued
Currant BIKES:
