Author Topic: 67` Bomber running problems  (Read 74062 times)
Online Bryanj
Re: 67` Bomber running problems
« Reply #60 on: May 20, 2024, 10:47:51 PM »
Honda part numbers are not complicate, the first numbers tell you what it is, the middle three what model first used on last three manufacturer or country code or supercision code so 283 is the model code you need, the supplier said sounds like 280 which is different
« Reply #61 on: May 21, 2024, 07:34:06 AM »
Yes it does have a recessed ring section on one side Mo.
I don't have access to it for a couple of days though to measure again.
« Reply #62 on: May 21, 2024, 09:26:55 AM »
Sorry Mo only just catching up with the thread. Been dealing with medical issues, two weeks holiday, the a bike trip to the Isle of Man to scatter my mates ashes. Busy few weeks.
If you have a look at   www.Cruzinimage.net   they have the sprocket and the tank rubbers you need. The sprocket I used was the 68-74 item (35 tooth) and it fit just fine. When you do the search use CB450K leave off the zero or you wont get any results. On this page, don't use any rubber items that come into contact with petrol or oil as they wont last. Don't use the gaskets as they are crap. And for heavens sake don't ask them any questions or they will blacklist you.
I don't think we used the same carb kits as mine were for a K3 and yours K0. Ironically I have two sets from Cruzinimage to rebuild my 14C's so I will get in the garage later and measure the needles against Ash's Honda upgrade parts that I will be using. I will report back later with what I find.
« Last Edit: May 21, 2024, 09:51:21 AM by royhall »
« Reply #63 on: May 21, 2024, 09:50:44 AM »
Just checked the carb parts, Ash's upgrade kit versus Cruzinimage K0 set. The needles mike up differently but are the same length, the drillings in the emulsion tubes are a different pattern and possibly different hole sizes. I am going to ultrasonic clean the upgrade parts and use them in the 14C build. I have a pair of rebuilt 14H on the bike at the moment but I still think it's running rich. Not really had chance to take it out recently so I could be wrong. Just waiting for some floats to rebuild the 14C then I will know for sure.
« Last Edit: May 21, 2024, 09:52:31 AM by royhall »
« Reply #64 on: May 21, 2024, 01:44:53 PM »
Ha Ha ...what brand of chocolate are the Cruzin sprockets made of Roy  ;D
« Reply #65 on: May 21, 2024, 04:19:10 PM »
I know what you mean Ash, but they do appear to be good quality. As with the rubber bits they may dissolve when you oil the chain though. Actually their piston kits are very high quality.
« Reply #66 on: May 21, 2024, 04:21:56 PM »
When I get a chance I will check the upgrade parts against the standard parts and see what the difference is.
« Reply #67 on: May 21, 2024, 06:26:54 PM »
Just checked the original needles that were in the carbs when I got them and they are the same as the upgrade needles. Must have already had the fix.
Offline mo goldie
« Reply #68 on: May 21, 2024, 07:23:00 PM »
Hi Roy
Welcome back ...sorry to here of you mates passing sounds like he has gone to the right place mate I,O,M.
Thanks for that info as just gone in and ordered both front and back Sprockets ...... did Not say anything about how long it would take to get here but at least then it should all be good............
As for the running of the bike I have sorted it and it run`s fine with no real issues so I am well pleased there is No flat spots around the 4,000 at all now but a bit of a flaff when starting up from cold on the left side but as soon as Hot No Problems, I have been playing around with the Mixture screws a lot as first time out on the over run it was popping and banging ..that turned a few heads :) but I have got it spot on now as the spark plugs are just the right Colour so Not running rich or weak....... so when I go out on it I don`t have any problems other than trying to get my head around the rev`s as at about 60 mph its doing around 6,000 revs....sounds like I am revving the guts out so to speak :) as Not used to having a bike that rev`s as high as that before.... that is one reason I wanted to put a 17 T front sprocket on to see if I bring the rev`s down,,,but Might be a bit of a tall order with going up 2 Teeth...so as I say just ordered the 15T and the 35T ...so thanks again Roy :)
Oh the Needles that I have Now got in are about 5mm longer that the ones Ash gave me to try.....they were with the bike when I got it.
« Last Edit: May 21, 2024, 07:24:54 PM by mo goldie »
Currant BIKES:
1980 Triumph Bonneville 750 T140/D Special Black & Gold
1962 BSA 650 Rocket Gold Star ( silver )
1977 Norton Commando 850 MK3  Interstate ( silver )
1977 Kawasaki KH400 Triple ( Green )
1999 Harley Davidson 1200S sportster Sport ( silver )
1975 Honda Monkey st70 Dax ( Blue )
1967 Honda CB450 KO Black Bomber
Online Bryanj
« Reply #69 on: May 21, 2024, 07:42:32 PM »
6000 is no where near the red line and dont think its anywhere near the 85% i would cruise at, cameras permitting!
Offline mo goldie
« Reply #70 on: May 22, 2024, 12:04:02 AM »
Well as I say Bryan
Not used to Revving an Engine that hard....yes as you say No where near the red line.... but i don`t thrash the Sh*T out of an engine I just want it to last. i did go to 80 ish at one point and the speedo needle when it hit that speed went right up and off the clock....... don't Know why but as soon as it came down it was fine again..dam gremlins.
but i am glad that it runs well Now and Not got the Rev flat spot No more...... as they say keep at it till you get it right and i do that to all my bikes....... some people say I over polish them too and they don`t look right...but as I say each to their own. I just like to look at a bike see if it`s looked after or Not if you know what I mean.
Currant BIKES:
Online Bryanj
« Reply #71 on: May 22, 2024, 02:09:59 AM »
Thats the big difference mate, old british iron was designed for ocasional sniff of the red but japanese was built to have its neck wrung, can remember the exact wording but the 500 owners handbook says it is fine to go into the red but not out of the top for extended periods!
« Reply #72 on: May 22, 2024, 08:52:51 AM »
Data says stroke of 450 is 57.8mm ..... in comparison to a 650 Bonneville @ 82mm, which is a huge difference in linear piston speed and giving the short stroke Honda an easier time, in kinetic terms, at any rpm. Both about 70mm bore too.
Crank rotation faster, but pistons moving slower sounds stressful, but mechanical effect is more gentle.
Also 360 degree crank vs 180 to give significant difference in balance at half stroke point in rotation.
Offline mo goldie
« Reply #73 on: May 22, 2024, 07:07:10 PM »
Well I will still keep the rev`s down as just need it to Cruise around on not sound as if I am ringing its neck LOL
Currant BIKES:
Offline mo goldie
« Reply #74 on: May 30, 2024, 06:42:23 PM »
Hi Roy
Thanks for the update of the parts and where to get them  ;D they came today and No import tax Yahoo LOL. a 35T Rear and the 15T Front so you know what I will be doing over the next few days ..what with the weather being like it is  :'(
but it will be all good I hope the sprockets look all to be ok.... update soon.
Cheers Mo
« Last Edit: May 30, 2024, 11:16:39 PM by mo goldie »
Currant BIKES:
