Author Topic: 1975 CB500K1 Engine reassembly in frame?  (Read 7867 times)
Offline martin_uk
« on: April 11, 2024, 09:17:17 PM »
Started to reassemble my CB500K1 engine and finding just the bottom end quite a lump to handle.
I wanted to double check that it is possible to reassemble everything in the frame once the crank case halves are together and installed and whether anyone else has tried.
I have a motorbike lift which means it is easier to work on at comfortable height.
I have rebuilt a number of CB750 sohc engines and no option other than to assemble up to cam cover, but I was a few years younger then  :D
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Re: 1975 CB500K1 Engine reassembly in frame?
« Reply #1 on: April 11, 2024, 09:31:25 PM »
Yes, it is easy to build up in the frame. Plenty of clearance available between top of breather cover and frame, unlike the 750's.
« Last Edit: April 11, 2024, 09:33:29 PM by Nurse Julie »
Offline martin_uk
« Reply #2 on: April 11, 2024, 09:42:34 PM »
Thanks Julie
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #3 on: April 11, 2024, 11:07:53 PM »
Make sure you leave the sump & oil filter off off it's pretty maneagable just as the crankcase halves, plenty of space to fit the block upwards afterwards.
I used a piece of cardboard in the shape of the sump held in place with a couple of bolts to keep the dog hairs out until I fitted the sump etc.
Offline martin_uk
« Reply #4 on: April 12, 2024, 12:29:38 PM »
Thanks Ted
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
