Author Topic: 550f master cylinder  (Read 24113 times)
Offline DomP
« on: April 20, 2024, 09:18:38 AM »
While replacing the standard bars with clip ons I've found as i suspected that the master cylinder gets on the way, can anyone recommend a modern replacement that may fir and have the same piston bore? Lots of cheap gsxr and ninja ones on Ebay
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
Re: 550f master cylinder
« Reply #1 on: April 20, 2024, 03:13:59 PM »
The reservoir and banjo fitting fouls the clip on clamp
1975 XS650B
« Reply #2 on: April 20, 2024, 07:40:40 PM »
Dom, try a 1995 CBR600 like this they work readily  available second hand then just a rebuild kit and a nanny
« Reply #3 on: April 20, 2024, 07:41:51 PM »
If you need one, I’ve got one in a re-built state with new piston and some paint if you need one mate
Offline DomP
« Reply #4 on: April 20, 2024, 09:07:36 PM »
Thanks Roo but that will still hit my clip ons, I need a radial mc ideally I think 5/8" or 14mm
1975 XS650B
« Reply #5 on: April 20, 2024, 09:09:20 PM »
Righto no worries worries Dom. Any progress piccies?
Offline DomP
« Reply #6 on: April 20, 2024, 09:36:35 PM »
Actually thinking about it a remote reservoir will work so maybe an sv650 mc?  I'll put some photos on my build thread Roo
1975 XS650B
« Reply #7 on: April 21, 2024, 03:59:16 AM »
Offline DomP
« Reply #8 on: April 21, 2024, 07:45:59 AM »
Do you sleep Roo!
1975 XS650B
Offline Nashfly
« Reply #9 on: April 21, 2024, 11:57:55 AM »
Not sure what you're looking for
On my race Honda 350 K4 I put an AP Lokheed adjustable one on, it matched the AP caliper. Got to the classic TT and everyone appeared to be using the David Silver (other suppliers are available ) replica ones, which cost less than the rebuild kit for my AP one!
I also have the DS  replica one on my Yamaha TZ race/road bike, it works well
Plus, I'll be fitting one on my Honda CB500 K2 RC181 replica
Online Bryanj
« Reply #10 on: April 21, 2024, 04:27:01 PM »
If its realy that much of an angle use one from a bmw airhead where the master is under the tank and operated by cable from the lever
« Reply #11 on: April 21, 2024, 04:40:11 PM »
Do you sleep Roo!
Not much these days sadly. 4am last night fiddling with carbs etc
Online Bryanj
« Reply #12 on: April 21, 2024, 04:51:23 PM »
NOT MY FAULT! You asked for the jets mate!!!
Offline DomP
« Reply #13 on: April 21, 2024, 07:21:06 PM »
On a single disc setup is going to a 5/8" mc going to be much of a problem?  That gives me lots of radial options
1975 XS650B
« Reply #14 on: April 21, 2024, 07:55:45 PM »
What's the original mc bore diameter on the 500 ? Is it 14mm ?
With that, 5/8 will give a hydraulic loss (disadvantage) but likely the mechanical on radial will be the opposite direction.
It shouldn't be too much in the way of overall effect, but only really thorough way is to try one.
If lever pivot is "bearing-ed" or very competent bush, and caliper is meticulously on target for free movement, seal condition etc, then highly probable it'll work well.
You'll not be far out of bed in reality, more a preference in how you like them to feel and ideal potency is going to be up for debate.
