Author Topic: CB550 Oil Filter Bolt Removal  (Read 42565 times)
Re: CB550 Oil Filter Bolt Removal
« Reply #15 on: April 24, 2024, 11:05:49 AM »
I have the standard Bahco 1/4 drive set that someone here recommended a great little set.
Bahco/SO/Blue Point group appear to have cornered the market.
« Last Edit: April 24, 2024, 11:08:28 AM by McCabe-Thiele (Ted) »
Offline Mike_Berkshire
« Reply #16 on: April 24, 2024, 03:52:18 PM »
Victory is mine! The bolt extractor sockets didnt work although a great purchase for future use. Eventually I had to opt for cold chisel and the big hammer - thank goodness for the flange under the bolt head.
« Reply #17 on: April 24, 2024, 03:57:28 PM »
Well done. Victory!
« Reply #18 on: April 24, 2024, 03:59:22 PM »
Good for you,
The idea of the small head, is to stop it being tightened to much,
I also grease the O ring under the head to prevent it sticking/corroding
Offline Deano400
« Reply #19 on: April 24, 2024, 04:09:23 PM »
Check for the washer between the spring and the oil filter. Often stuck to the oil filter and often accidentally binned. I have 3 engines here and none of them had the washer.
BTW mine are 400s, I imagine yours has a similar washer.
« Reply #20 on: April 24, 2024, 04:30:02 PM »
Result - you can't sometimes beat brute thuggery.👍👍👍
« Reply #21 on: April 24, 2024, 04:35:20 PM »
Yes, the 500 has them
Fit between filter and spring
« Reply #22 on: April 24, 2024, 05:05:57 PM »
Nope - no washer on the one I removed. Spring, yes. Washer, nope.
« Reply #23 on: April 24, 2024, 05:38:19 PM »
A lot of owners throw the washer out with the old filter, over the padt 3 weeks, I've sold 15 of them from my Ebay page 😂😂😂
Offline davidcumbria
« Reply #24 on: April 24, 2024, 06:40:56 PM »
Well done  Mike - very satisfying to overcome such problems
David
Offline ozzybud
« Reply #25 on: April 24, 2024, 06:45:39 PM »
Great feeling. Good job
Very surprised the stud extractor did not work. Did you use the one size smaller than the one that fit and tap it on?
« Last Edit: April 24, 2024, 06:48:03 PM by ozzybud »
1976 Z50 PARAKEET YELLOW
1970 CT70 CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVERA BLUE
1973 CB350F FLAKE MATADOR RED
1974 CB350F GLORY BLUE BLACK
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #26 on: April 24, 2024, 09:49:29 PM »
Yes and it just tore off some of the remaining metal but there was just a small nub left.
Still I’m sure they will come in useful in the future
Offline Jan B
  • Everything you can leave behind is a gain
« Reply #27 on: April 26, 2024, 10:34:00 AM »
You must be chuffed.
What replacement bolt will you be using? There are non OEM bolts with a larger hex. Less change to get mangled.
« Last Edit: April 29, 2024, 11:11:20 AM by Jan B »
CB500K1
CB750K2 [project]
BMW F800GS
« Reply #28 on: April 26, 2024, 01:37:47 PM »
You ust be chuffed.
Thanks Jan! Yes chuffed but more relieved that I got it out OK. I havent yet thought about what replacement but a good call that some have larger bolt heads. I will also need the washer that goes between the spring and oil filter. It was either never there or I threw it out with the old (ancient) oil filter I removed. I did have a dig through the bin but didnt find anything.
