Author Topic: Rev counter blank  (Read 11153 times)
Offline DomP
« Last Edit: April 27, 2024, 03:08:24 PM by DomP »
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: Recounted blank
« Reply #1 on: April 27, 2024, 02:59:02 PM »
Extremely doubtful
Offline DomP
Re: Recounted blank
« Reply #2 on: April 27, 2024, 03:08:58 PM »
Extremely doubtful
I'm ever the optimist!
1975 XS650B
Re: Rev counter blank
« Reply #3 on: April 27, 2024, 03:31:47 PM »
Couldn't you cut a piece of 6mm alloy to shape, drill for the screw,
Make a gasket, and fit??
Or you could buy a sheet of carbon fibre, the sort that is used for models,
Offline DomP
« Reply #4 on: April 27, 2024, 03:40:41 PM »
I thought it might need an insert with an oring to seal but you are probably right, certainly worth trying
1975 XS650B
Online Bryanj
« Reply #5 on: April 27, 2024, 03:44:03 PM »
Just leave the cable off but fit the drive housing, there is an oil seal in there
Offline DomP
« Reply #6 on: April 27, 2024, 05:06:53 PM »
Good point Bryan!
1975 XS650B
Online Bryanj
« Reply #7 on: April 27, 2024, 05:12:27 PM »
With the drive gear of course!
« Reply #8 on: April 27, 2024, 06:38:55 PM »
I don’t understand the sizing of that so don’t really know Dom, somebody with far superior marbles will probably be along shortly to tell you. It’s a bit dear at nearly 30 quid though.
This is similar to what I used and it’s a dead tight fit so not coming out, think I had to tap it in with a block of wood to get it in right but fits a treat for less than 10 bob
