Author Topic: died in the driveway  (Read 5841 times)
Offline chink1957
« on: September 27, 2010, 10:03:47 AM »
My 1977 honda cb750f supersport died in the driveway of my sister's house after starting without incident.  I checked fuses and changed but to no avail.  Battery is relatively new.  I am flummoxed by situation.  Any input or insight would be greatly appreciated.
chink57
Re: died in the driveway
« Reply #1 on: September 27, 2010, 10:07:19 AM »
Basic checks to start with:
1. Kill switch nudged (or shorting out)?
2. Remove a plug - is it wet?
3. Do you get a spark on the removed plug when held against the cylinder head?
I'm assuming that the engine turns over on the starter?
Steve
« Reply #2 on: September 27, 2010, 01:53:34 PM »
If it got the ignition switch between the clocks make sure the multi plug is still in and the switch bottom hasny fallen off
Offline PMK
  • Destroyer of Fine Motorcycles & Idiot for Hire
    • Karpettiger Maine Coon Cats
« Reply #3 on: September 27, 2010, 06:38:55 PM »
Mine died after starting well for ages.
Is there a rattle from the kickstart side?
Mine was the rotor on the end of the crank had come adrift.
It's on the kick start side under the cover at the front held by 2 screws.
Check there
He who breaks something to see how it works has left the path of wisdom and become an engineer
Honda CB750F2 1978
Harley Sportster 883 1999
Matchless G80 1960
« Reply #4 on: September 28, 2010, 07:20:37 PM »
Does it do anything  i.e. ignition light and starter motor or is it totally dead.
Try "flicking" the ignition key on and of to see if contacts are not making, you amy see a flicker if this is the prob Better at night as you can see any response in the dark.
Offline chink1957
« Reply #5 on: September 29, 2010, 03:22:41 AM »
Thanks for the expeditous replies.  I won't be able to get back to her until thursday, she is 26 miles away and I am stuck on Nightshift until then.  But, bye the bye, I had nothing.  I will check all of your suggestions as soon as i can and let you know what happened.  Thanks again.
Chink1957
Offline Yoshi823
  • Biker to the bone...
« Reply #6 on: October 04, 2010, 11:42:13 PM »
Sounds like the ignition switch itself...i've had the same in the past.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
« Reply #7 on: October 05, 2010, 11:12:53 AM »
Had a similar thing happen to me on my CB750F, went to Liverpool, the bike was running great stopped at the daughters and it went as dead as a dodo, checked the fuses all OK, in the end it was the connections behind the fuses that were the problem, lots of corrosion.
Den
Offline Dave M
« Reply #8 on: October 06, 2010, 11:44:18 AM »
Same thing happened to me on a K6.
Turned out the contacts in the ignition switch had burnt out.
Despite being told that the switch couldn't be removed rom the lock assembly, I removed it and swapped it from an ignition I managed to get with no keys.
Worked fine after that.
Dave
Melbourne.
Offline chink1957
« Reply #9 on: October 20, 2010, 09:46:38 AM »
Just a quick follow-up.  As it turned out, it was the ignition switch.  It was  replaced my my local motorcycle shop and replace the archaic fuses as well.  Again, thank you for the input.
chink1957
